Mazak CNC machine control error List for MAZATROL MATRIX etc.
For other Mazak alarm lists visit following pages.
- Mazak System/Drive error ( No. 1 – No. 99, No. 1000 – No. 1099 )
- Mazak CNC machine control error ( No. 100 – No. 199, No. 1100 – No. 1199 )
- Mazak PLC machine control error ( No. 200 – No. 399, No. 1200 – No. 1399 )
- Mazak CNC screen operation error ( No. 400 – No. 499, No. 1400 – No. 1499 )
- Mazak I/O error ( No. 500 – No. 599, No. 1500 – No. 1599 )
- Mazak MAZATROL program error ( No. 600 – No. 699, No. 1600 – No. 1699 )
- Mazak MAZATROL program error ( No. 700 – No. 799, No. 1700 – No. 1799 )
- Mazak EIA/ISO program error ( No. 800 – No. 899, No. 1800 – No. 1899 )
- Mazak EIA/ISO program error ( No. 900 – No. 999, No. 1900 – No. 1999 )
- Mazak Interference error ( No. 2100 – No. 2199 )
Contents
- CNC Machine Control Error
- 100
- 101 SOFT LIMIT
- 113 OVER TRAVEL
- 125 ILLEGAL AXIS EXISTS
- 126 AXIS HAS NOT PASSED Z PHASE
- 127 ILLEGAL DIR. FOR ORIGIN RETURN
- 128 OUTSIDE INTERLOCK AXIS
- 129 INSIDE INTERLOCK AXIS
- 130 NO OPERATION MODE
- 131 CUTTING FEED OVERRIDE ZERO
- 132 FEEDRATE ZERO
- 133 STOP SPINDLE
- 134 SPINDLE ROTATION EXCEEDED
- 135 BLOCK START INTERLOCK
- 136 CUTTING BLOCK START INTERLOCK
- 137 DYNAMIC COMPENSATION EXCEEDED
- 138 CANNOT ROTATE TABLE
- 139 PRE-INTERP ACCEL/DECEL ERROR
- 140 ILLEGAL REFERENCE RETURN No.
- 141 EXCESS SIMULTANEOUS ERROR
- 142 NONE OR DUPLICATE OPERAT. MODE
- 143 ILLEGAL HANDLE FEED AXIS
- 145 REQUIRE ABSOLUTE RECOVERY
- 146 NOT AUTO MODE
- 147 C AXIS TURNING ANGLE OVER
- 148 CHUCK BARRIER
- 149 TAILSTOCK BARRIER
- 150 WORK PIECE BARRIER
- 151 NO TANDEM CONTROLLING OPTION
- 152 ILLEGAL SYNCHRONIZED AXIS NAME
- 153 TRANSFER/PUSH UNFINISHED
- 154 ZERO RET. NOT ALLOWED (G68 MODE)
- 155 BARRIER TURRET/TOOL HEAD
- 156 ILLEGAL MEASURING SENSOR SIGNAL
- 157 MEASURED RESULT MALFUNCTION
- 158 ILLEGAL COMMAND CROSS MACHINING
- 160 ILLEGAL NUMBER OF CROSS AXIS
- 161 SUPERPOSITION CTRL IMPOSSIBLE
- 162 ILLEGAL SUPERPOSITION PARAMETER
- 163 BARRIER WORK
- 164 ILLEGAL CMD SAFE OPER SYS ALARM
- 165 CANNOT MAKE SAFE OPER SYS ACTIVE
- 166 LOWER TURRET ALREADY ASSIGNED
- 167 ILLEGAL OPER TOOL TIP PT CTRL
- 168 ILLEGAL OPER 5X RADIUS COMP.
- 169 HIGH SMOOTHING CTR. ILLEGAL OPE
- 170 W AXIS THRUST FORCE SHORTAGE
- 171 W AXIS THRUST SUPPLYING
- 172 B AXIS NOT AVAILABLE
- 173 2ND SPDL C AXIS NOT AVIALABLE ( , , ) B I N Red
- 174 2ND SPDL 1/1000 N/A
- 175 TABLE UNBALANCE CHECK N/A
- 176 CANNOT CHANGE TIME CONSTANT
- 177 ILLEGAL COMMD TIME CONST. CHANGE
- 178 INERTIA TOO LARGE
- 179 CANNOT AUTO MEASURE INERTIA
- 191 FILE SYSTEM I/O ERROR
- 192 EXECUTION IMPOSSIBLE
- 193 NO TOOL IN MAGAZINE
- 194 NO TOOL DATA IN PROGRAM
- 195 WRONG MEASURING DIRECTION
- 196 WRONG MEASURING POINT
- 197 UNREGISTERED HEAD DATA
- 198 NO HEAD DATA
- 199 DIVISION BY ZERO
- 1101 INTERFERE
- 1102 INTERFERE
- 1103 INTERFERE CHECK DATA OVERLOAD
100
Cause
Action
101 SOFT LIMIT
Cause
Some mistake in operations during the automatic operation has caused the tool tip to overstep the area specified in the software limit parameters in the direction of the axis corresponding to the displayed axis name.
Action
Modify the program so that the tool tip may move within the area specified in the software limit parameters.
113 OVER TRAVEL
Cause
The tool tip has reached stroke limit in the direction of the axis corresponding to the displayed axis name.
Action
Move the tool tip away from the end in manual operation mode.
Cause
During reference-point return, the proximity-point detection limit switch has overrun the position in which the watchdog is mounted.
Action
Either extend the length of the proximity-point watchdog or reduce the reference-point returning speed. After that, carry out the zero-point returning operation once again.
Cause
During initial reference-point return following the power-on action, an axis has not passed through the Z phase of the corresponding detector.
Action
First actuate the handle for manual pulse feed to move the axis back in the opposite direction to the zero-point, and then carry out the zero-point returning operation once again.
Cause
The axis-movement direction selected with the axis selector button is not correct for the reference-point return in manual operation mode.
Action
Set the correct direction (+, –) using the axis selector buttons.
Cause
An axis is interlocked because the interlock function has become active (input signal has turned off).
Action
Clear the active state of the interlock function.
Cause
The very direction in which the manual skip function has become effective is specified in the axis-movement command. Or the servo-off function is active.
Action
Deactivate the servo-off function.
Cause
This message is displayed in the event of incorrect mode selection or a mode selector switch malfunction.
Action
Contact Mazak Technical Center or Technology Center.
Cause
The cutting-feed override value is set to 0 on the machine operating panel.
Action
Change the cutting-feed override value to one greater than 0. If this alarm message is displayed when the cutting-feed override value is not 0, check the signal line for a short-circuit.
132 FEEDRATE ZERO
Cause
An attempt has been made to execute an axis movement in the cutting feed mode or dry-run in the automatic operation mode, with the manual feedrate remaining set to 0 on the machine operating panel.
Action
Change the manual feedrate to a value greater than 0. If this alarm message is displayed when the manual feedrate is not 0, check the signal line for a short-circuit.
133 STOP SPINDLE
Cause
Spindle rotation did not start when the spindle rotation start command was issued during automatic operation.
Action
The spindle amplifier and the encoder must be checked for normal operation. Contact Mazak Technical Center or Technology Center.
Cause
The spindle-speed limit has been exceeded.
Action
Reduce the spindle speed. The spindle amplifier must be checked for normal operation. Contact Mazak Technical Center or Technology Center.
Cause
The interlock signal to lock the start of the program block has been input.
Action
The sequence program needs checking for normal functioning. If this alarm should occur seemingly without cause, contact Mazak Technical Center or Technology Center.
Cause
The interlock signal to lock the start of the cutting program block has been input.
Action
Cause
Dynamic compensation amount exceeded 3 mm (0.12 in.).
Action
Make sure that the workpiece coordinate zero point is centrally positioned in the workpiece, and set the difference between the center of the workpiece and the rotary center of the table to 3 mm (0.12 in.) or less.
Cause
There are areas where the machining with table rotation cannot be executed.
Action
Modify the approach point.
Cause
Trouble has occurred during pre-interpolation acceleration/deceleration.
Action
Cause
Returning to the second reference point has been commanded in spite of the fact that returning to the first reference point has not yet occurred.
Action
Return the axis to the first reference point first.
Cause
The synchronization error between the master axis and the slave axis during synchronous control has overstepped a predetermined allowable value.
Action
Move either axis in the direction that the error decreases. Reduce the allowable value to zero (checking invalid), or increase the allowable value.
Cause
An operation mode has not been selected, or more than one operation mode have been selected. The operation mode selector switch is malfunctioning.
Action
Check for incorrect wiring of the input mode switch.
Cause
A nonexistent axis has been designated as the handle feed axis. Or a handle feed axis has not been designated.
Action
Check the handle feed axis selection signal line for incorrect wiring. Or check the maximum number of axes that can be used under the current specifications.
Cause
The absolute position data has become lost.
Trouble has occurred in the absolute position detector.
Action
Require Mazak Technical Center or Technology Center to restore the normal conditions for the zero-point return.
146 NOT AUTO MODE
Cause
The cycle start button was pressed when the machine was not in the automatic mode.
Action
Change the mode to the automatic and then restart the machine.
Cause
1. The rotational angle limit at the shaping block connections has been exceeded.
2. The radius of the arc is less than the rotational radius of the C-axis.
Action
1. Review the program.
2. Review the setting of parameter K1 (rotational radius of the C-axis).
148 CHUCK BARRIER
Cause
The tool entered in the chuck barrier.
Note: Turning spindle number where alarm has occurred is displayed.
Action
Modify the barrier-related parameters or, for automatic operation, review and correct the program.
Cause
The tool entered in the tail barrier.
Action
Correct the machining program. If the program is correct, review the tool data and the parameters related to the barrier.
Cause
Interference is occurring between the workpiece of the No. 1 turning spindle side and the workpiece of the No. 2 turning spindle side.
Action
Correct the machining program. If the program is correct, review the parameters related to the barrier.
Cause
Executing the tandem driving function has been attempted despite a tandem driving option not being present.
Action
The tandem driving function can be used only for a special machine. If this alarm occurs in a special machine that allows the use of the tandem driving function, contact Mazak Technical Center or Technology Center.
Cause
1. The setting of the slave axis name in parameter M11 is not correct.
2. The name of the master axis that is specified for synchronous control does not correspond with the setting of the axis naming parameter.
Action
1. Set the name of the slave axis with a small letter.
2. With reference to the parameter, specify the correct axis as the master one for synchronous control.
Cause
1. The axis reached its pressing completion position before a skipping signal was generated.
2. The drooping amount during pressing operation cannot overstep the setting in parameter K46.
Action
1. Check whether the pressing completion position in the program is correct.
2. Modify the K46 setting as appropriate.
Cause
Zero-point return mode has been selected during three-dimensional coordinate conversion.
Action
1. Select an operation mode other than the zero-point return mode.
2. To execute manual zero-point return, cancel three-dimensional coordinate conversion mode.
Cause
The barriers of the upper and lower turrets interferes with each other.
Action
Cause
The sensor signal for tool measurement turned on during preparation for measurement.
Action
Start the measurement after the preparation.
Cause
All the results of repeated measurements did not fall within the tolerance for compensation.
Action
Check the program.
Check if the sensor tool length registered on the TOOL DATA display is correct.
Check the mounting status of the sensor.
Cause
It was attempted to manually control an axis currently under the control for cross machining.
Action
The axes under the cross machining control cannot be controlled manually.
Cause
The number of axes in the remote system has become zero as a result of crossing command execution.
Action
Review and correct the program.
Cause
It was attempted to start superposition control with an unavailable axis.
It was attempted to start superposition control under incompatible modal conditions.
Action
Check the parameters related to the type of acceleration & deceleration and to the motion speed during superposition control.
Cause
Incorrect parameter settings do not allow the superposition control to be started.
Action
163 BARRIER WORK
Cause
There is a danger that one workpiece will interfere with the other.
There is a danger that the partition plate will interfere with the workpiece or the lower turret.
Action
Cause
With the machine under the control for safety speed, a command for the following was given:
Threading, Synchronous tapping, Cross machining, Superposition control.
Action
Close the door to operate the machine.
Cause
The command signal for the control for safety speed was turned on in the following modes of machining:
Action
Cause
An M810 command was given from one HD side to operate the lower turret that was currently used on the other HD side.
Action
Give the M810 command after the use of the lower turret on the other side.
Cause
In the mode of tool tip point control an unavailable operation (e. g. manual interruption) was attempted.
Action
Manual interruption cannot be performed in the mode of tool tip point control.
Cause
In the mode of tool radius compensation for five-axis machining an unavailable operation (e. g. manual interruption) was attempted.
Action
Manual interruption cannot be performed in the mode of tool radius compensation for five-axis machining.
Cause
In the mode of high-speed smoothing control an unavailable operation (e. g. manual interruption) was attempted.
Action
Manual interruption cannot be performed in the mode of high-speed smoothing control.
Cause
W-axis thrust has not been obtained.
Action
Cause
W-axis operation was programmed during the application of the W-axis thrust.
Action
Cause
The head (B) axis is used without the B-axis control option.
Action
Purchase the B-axis control option.
Cause
The No. 2 spindle/C-axis is used without the No. 2 spindle/C-axis option.
Action
Purchase the No. 2 spindle/C-axis option.
Cause
The No. 2 spindle/C-axis is used without the No. 2 spindle high-precision indexing option.
Action
Purchase the No. 2 spindle high-precision indexing option.
Cause
Vibration detection is used without the rotary table vibration detection option.
Action
Purchase the rotary table vibration detection option.
Cause
Changing the cutting feed time constant in the system has been attempted during synchronous tapping, threading, or control axis superposition.
Action
Cause
The inertia estimation has been attempted by G297 during movement of the axis whose inertia was to be estimated.
The G298 parameter setup command has been set during movement of the parameter setup reference axis or of some axis assigned to the parameter data development system.
The G298 parameter setup command has been set during cutting feed time constant changeover or control axis superposition.
The G298 parameter setup command has been set during axis rotation.
Action
Cause
The estimated inertia has exceeded the maximum inertia specified in the TSVC parameter or the TSPC parameter.
Action
Correct the settings of the TSVC parameter or the TSPC parameter.
Cause
Resonance has not been reduced during inertia estimation.
The minimum inertial is not specified in TSVC or TSPC.
The inertia estimation itself has failed.
Action
Cause
An internal error(s) has occurred during program data change by the function of VFC, MMS etc.
Action
After checking the entire data of the program being executed, tool data, tool file, parameters, etc., save the data using the data I/O operation and then contact Mazak Technical Center or Technology Center.
Cause
An internal error(s) has occurred during execution of the MMS unit.
Action
Cause
Tool data that correspond to the pocket numbers being displayed in the “TNo.” item of the POSITION display are unregistered.
Action
Register the tool data.
Cause
An internal error(s) has occurred when circumferential speed or feedrate changing by VFC function was under way.
Action
After checking the entire data of the program being executed, tool data, tool file, parameters, etc., save the data using the data I/O operation (floppy disk) and then contact Mazak Technical Center or Technology Center.
Cause
During the second or subsequent rounds of manual measurement, an attempt has been made to perform skipping in a direction not available for measurement.
Action
Perform measurements in the correct direction.
Cause
During the second or subsequent rounds of manual measurement, an attempt has been made to measure an illegal point.
Action
Measure correct points.
Cause
Head data of the head number being used during MMS, MDI MMS or manual measurement does not exist.
Action
198 NO HEAD DATA
Cause
Head data of the head number being used during MMS, MDI MMS or manual measurement is partly missing.
Action
Cause
An attempt has been made to carry out divisions by zero inside the NC unit during measurement of the degree-ofstraightness on the MEASURE display.
Action
Check the touch sensor for abnormalities.
Carry out measurements once again if the touch sensor is normal.
1101 INTERFERE
Cause
Interference occurs between and .
Action
Press the cancel key to clean the alarm.
1102 INTERFERE
Cause
Action
Press the reset key to clean the alarm.
Cause
The Intelligent Safety Shield process was not in time.
Action
Set a simple workpiece model or a fixture model or a tool model.
