Mazak INTEGREX M code list for cnc machinists.
Miscellaneous Function (M-Code) for the Mazak INTEGREX 300/400-III/III T/IIIS/IIIST
Mazak M Code List
M-codes | Description |
M00 | Program stop |
M01 | Optional stop |
M02 | Program end |
M03 | Spindle normal rotation |
M04 | Spindle reverse rotation |
M05 | Spindle stop |
M06 | Chuck unclamp (releasing workpiece) |
M07 | Chuck clamp (holding workpiece) |
M08 | Flood coolant ON |
M09 | Coolant OFF |
M10 | |
M11 | |
M12 | Milling spindle mode cancel (Turning mode selection) |
M13 | Milling tool normal rotation |
M14 | Milling tool reverse rotation |
M15 | Milling tool stop |
M16 | Spindle orientation 0° (for AJC) |
M17 | Spindle orientation 120° (for AJC) |
M18 | Spindle orientation 240° (for AJC) |
M19 | Spindle orientation position (for the robot to insert a workpiece) |
M20 | Robot service call |
M21 | Robot service call |
M22 | Robot service call |
M23 | Robot service call |
M24 | Robot service call |
M25 | Robot service call |
M26 | Robot service call |
M27 | Robot service call |
M28 | Robot service call |
M29 | Robot service call |
M30 | Reset & tape rewind |
M31 | Tail spindle & tailstock body advance (for 300/400-III/IIIT) |
M32 | Tail spindle & tailstock body retract (for 300/400-III/IIIT) |
M33 | Low chuck pressure |
M34 | High chuck pressure |
M35 | |
M36 | |
M37 | |
M38 | |
M39 | |
M40 | |
M41 | |
M42 | |
M43 | |
M44 | |
M45 | Air coolant blow ON (coolant stop: M09) |
M46 | |
M47 | |
M48 | Parts catcher advance |
M49 | Parts catcher retract |
M50 | |
M51 | Error detect OFF |
M52 | Error detect ON |
M53 | Chamfering OFF |
M54 | Chamfering ON |
M55 | Piece count |
M56 | Front door open |
M57 | Front door close |
M58 | Chuck air blast |
M59 | |
M60 | C-axis unclamp |
M61 | |
M62 | |
M63 | |
M64 | |
M65 | |
M66 | C-axis clamp |
M67 | C-axis brake (for machining by G01) |
M68 | Cycle bar feeder call 1 |
M69 | Cycle bar feeder call 2 |
M70 | |
M71 | |
M72 | Inside chuck clamp |
M73 | Outside chuck clamp |
M74 | Steady rest – milling head connection mode release |
M75 | Steady rest – milling head connection mode start |
M76 | |
M77 | |
M78 | |
M79 | |
M80 | |
M81 | Workpiece measurement start |
M82 | Workpiece measurement end |
M83 | Tool measurement start |
M84 | Tool measurement end |
M85 | |
M86 | Steady rest 1 unclamp |
M87 | Steady rest 1 clamp |
M88 | Steady rest 2 unclamp |
M89 | Steady rest 2 clamp |
M90 | |
M91 | |
M92 | |
M93 | |
M94 | |
M95 | |
M96 | User macro interruption, valid |
M97 | User macro interruption, invalid |
M98 | EIA → EIA Subprogram call |
M99 | EIA → EIA Return to main EIA program |
M100 | Workpiece measurement DIA start |
M101 | Workpiece measurement DIA end |
M102 | Workpiece measurement STP start |
M103 | Workpiece measurement STP end |
M104 | Workpiece measurement GRV start |
M105 | Workpiece measurement GRV end |
M106 | Workpiece measurement WID start |
M107 | Workpiece measurement WID end |
M108 | Workpiece measurement DIS start (chuck barrier release) |
M109 | Workpiece measurement DIS end |
M110 | Tool tip measurement TOL start |
M111 | Tool tip measurement TOL end |
M112 | External tool compensation EXT start |
M113 | External tool compensation EXT end |
M114 | Z-axis offset measurement ZOF start |
M115 | Z-axis offset measurement ZOF end |
M116 | C-axis offset measurement COF start |
M117 | C-axis offset measurement COF end |
M118 | |
M119 | |
M120 | Measurement data print out |
M121 | |
M149 | |
M150 | Workpiece unload demand to robot |
M151 | Milling spindle through air blow ON (Only for turning tools) |
M152 | Milling spindle through air blow OFF (Only for turning tools) |
M153 | Milling spindle through coolant ON |
M154 | Milling spindle through coolant OFF |
M155 | Chuck coolant ON (composed movement) |
M156 | Chuck coolant OFF (composed movement) |
M157 | Spindle through coolant blow ON (OFF: M159) |
M158 | Spindle through air blow ON (OFF: M159) |
M159 | M157, M158 OFF |
M160 | Shower coolant ON/chuck stopper extend |
M161 | Shower coolant OFF/chuck stopper retract |
M162 | Workpiece rechucking (for a piece delivered by robot) |
M163 | Tail spindle thrust low pressure (for 300/400-III/IIIT) |
M164 | Tail spindle thrust high pressure (for 300/400-III/IIIT) |
M165 | |
M166 | |
M167 | |
M168 | |
M169 | 35K, 70K high pressure coolant ON (OFF: M9, M154) |
M170 | |
M171 | |
M172 | Index 0°(KOUYOU) |
M173 | Index 90°(KOUYOU) |
M174 | Index 180°(KOUYOU) |
M175 | Index 270°(KOUYOU) |
M176 | Index 270°(KOUYOU) |
M177 | Index 270°(KOUYOU) |
M178 | Index 270°(KOUYOU) |
M179 | Index 270°(KOUYOU) |
M180 | |
M197 | |
M198 | EIA → MAZATROL program call |
M199 | EIA → MAZATROL program end |
M200 | Milling point machining start |
M201 | Milling line machining start |
M202 | Turning mode |
M203 | Milling tool normal rotation |
M204 | Milling tool reverse rotation |
M205 | Milling tool stop |
M206 | |
M207 | M208, M209 mode cancel |
M208 | ATC prohibition mode during finishing, coolant ON |
M209 | ATC prohibition mode during finishing, coolant OFF |
M210 | C-axis clamp (for milling) |
M211 | C-axis brake (for milling) |
M212 | C-axis unclamp (for milling) |
M213 | C-axis brake only (brake by M211) |
M214 | C-axis unclamp only (unclamp by M212) |
M215 | M213, M214 and M216 mode cancel |
M216 | C-axis unclamp neglect mode (cancel: M215) |
M217 | |
M218 | |
M219 | Milling tool orient |
M220 | |
M229 | |
M230 | Grinding mode ON |
M231 | Grinding speed setting |
M232 | |
M233 | |
M234 | |
M235 | |
M236 | C-axis servo gain normal |
M237 | C-axis servo gain low |
M238 | C-axis servo gain middle |
M239 | C-axis servo gain high |
M240 | |
M241 | |
M242 | |
M243 | |
M244 | |
M245 | |
M246 | |
M247 | |
M248 | Spindle speed check (for interlocking the start of cutting) |
M249 | Milling head selection preparation |
M250 | Milling head/B-axis unclamp |
M251 | B-axis clamp |
M252 | Milling spindle unclamp |
M253 | Milling spindle clamp |
M254 | Milling head/B-axis clamp |
M255 | |
M256 | |
M257 | |
M258 | Milling head air blow |
M259 | |
M260 | Polygon mode ON |
M261 | Polygon mode OFF |
M262 | |
M273 | |
M274 | Steady rest coolant ON |
M275 | Steady rest coolant OFF |
M276 | |
M330 | |
M331 | Spindle coil change fixed to high speed |
M332 | Spindle coil change, valid |
M333 | |
M347 | |
M348 | Yt-axis selection |
M349 | Y-axis selection |
M350 | |
M351 | M352 cancel |
M352 | Spindle speed arrival signal check, valid |
M353 | |
M369 | |
M370 | Axis load detection, invalid |
M371 | Axis load detection, valid |
M372 | Axis load detection, temporarily invalid |
M373 | Axis load detection, re-start |
M374 | NC feed holding on overload detection |
M375 | NC feed holding & spindle stop on overload detection |
M376 | Overload detection level % setting |
M377 | Overload detection time setting (unit: 0.1 sec) |
M378 | Overload detection peak %/detection frequency setting |
M379 | Overload detection table No. registration |
M380 | |
M389 | |
M390 | M391 cancel |
M391 | Spindle mis-chucking cancel (M3/M4 completed with chuck open) |
M392 | |
M393 | |
M394 | TOOL EYE extension possible during chuck close (when robot valid) |
M395 | M394 cancel |
M396 | |
M600 | |
M601 | Magazine tool rotation |
M602 | |
M730 | |
M731 | Tail thrust 1 selection |
M732 | Tail thrust 2 selection |
M733 | Tail thrust 3 selection |
M734 | Tail thrust 4 selection |
M735 | Tail thrust 5 selection |
M736 | Tail thrust 6 selection |
M737 | Tail thrust 7 selection |
M738 | Tail thrust 8 selection |
M739 | Tail thrust 9 selection |
M740 | Tail thrust 10 selection |
M741 | Positioning tailstock to “Position 1” |
M742 | Positioning tailstock to “Position 2” |
M743 | Positioning tailstock to “Retract” |
M744 | |
M927 | |
M928 | Y-axis zero point return |
M929 | |
M930 | Yt-axis moving to ATC position |
M931 | |
M999 |
