Mazak plc alarm list for cnc machinists. Alarm List for the Mazak INTEGREX 300/400-II
For other Mazak alarm lists visit following pages.
- Mazak System/Drive error ( No. 1 – No. 99, No. 1000 – No. 1099 )
- Mazak CNC machine control error ( No. 100 – No. 199, No. 1100 – No. 1199 )
- Mazak PLC machine control error ( No. 200 – No. 399, No. 1200 – No. 1399 )
- Mazak CNC screen operation error ( No. 400 – No. 499, No. 1400 – No. 1499 )
- Mazak I/O error ( No. 500 – No. 599, No. 1500 – No. 1599 )
- Mazak MAZATROL program error ( No. 600 – No. 699, No. 1600 – No. 1699 )
- Mazak MAZATROL program error ( No. 700 – No. 799, No. 1700 – No. 1799 )
- Mazak EIA/ISO program error ( No. 800 – No. 899, No. 1800 – No. 1899 )
- Mazak EIA/ISO program error ( No. 900 – No. 999, No. 1900 – No. 1999 )
- Mazak Interference error ( No. 2100 – No. 2199 )
Mazak PLC Alarm List
- 200 THERMAL TRIP (EMERGENCY STOP)
- 201 BREAKER TRIP
- 202 HYDRAULIC PRESSURE DOWN
- 203 AIR PRESSURE DOWN
- 204 SPINDLE CONTROLLER MALFUNCTION
- 205 MILLING CONTROLLER MALFUNCTION
- 206 OPEN FRONT DOOR (EMERGENCY STOP)
- 211 NOT OPERATED MCODE SIMULTA.
- 212 CHUCK OPEN/CLOSE SWITCH MALF.
- 213 ILLEGAL DESIGNATED TOOL No.
- 215 CHUCK SYSTEM MALFUNCTION
- 218 CHUCKING TYPE NOT SELECTED
- 220 TURRET POSITION SENSOR MALF.
- 221 TURRET CLAMP SENSOR MALFUNCTION
- 224 CHUCK SENSOR MALFUNCTION
- 225 FRONT DOOR SENSOR MALFUNCTION
- 231 TOOL EYE POSITION SENSOR MALF.
- 234 TOOL CLAMP SENSOR MALFUNCTION
- 236 PARTS-CATCHER SENSOR MALF.
- 243 MEASURING CONTROLLER MALF.
- 245 BAR-FEEDER CONTROLLER MALF.
- 248 EXTERNAL CONTROLLER (No.1) MALF.
- 250 SPINDLE START MISOPERATION
- 251 MILLING MOTOR ROTATION PROHIB.
- 252 AXIS MOVE MISOPERATION
- 253 OVERLOAD DETECTION
- 256 TURRET ROTATION PROHIBITED
- 257 ILLEGAL M-CODE
- 258 TNo. MISMATCH
- 259 MODE CHANGE IMPOSSIBLE
- 260 SLIDEWAY LUBRICATION ALARM
- 261 HEAD LUBRICATION ALARM
- 264 THERMAL TRIP X5 (SINGLE BLOCK)
- 267 BALL SCREW X44C LUBRICATION ALARM
- 270 SPINDLE ORIENT EXCEED TIME
- 272 TURRET INDEX EXCEED TIME
- 275 ROBOT SERVICE EXCEED TIME
- 276 ATC CYCLE EXCEED TIME
- 279 PARTS CATCHER CYCLE EXCEED TIME
- 282 CHUCK CLAMP EXCEED TIME
- 286 FRONT DOOR EXCEED TIME
- 292 SENSOR MALFUNCTION No. 3
- 293 SENSOR MALFUNCTION No. 4
- 297 CHUCK PRESSURE DOWN
- 300 START COND. ERR. (DOOR OPEN)
- 301 START COND. ERR. (TUR UNCLAMP)
- 302 START COND. ERR. (EXT RESET)
- 303 START COND. ERR. (EXT FEED HOLD)
- 308 C/S ERROR (TOOL EYE EXTEND)
- 310 C/S ERROR (TNo.MISMATCH)
- 311 C/S ERROR (TAIL STOCK QUILL)
- 312 C/S ERROR (PTCATCHER EXTEND)
- 313 C/S ERROR (C/S QUILL COMMAND)
- 320 TOOL UNCLAMP IMP. (M-SP ROT.)
- 321 MODE CHANGE IMPOSSIBLE (DURING ATC CYCLE)
- 322 RAPID MODE IMP. (ORIGIN RET UNF)
- 324 DIFF. MODE (ORIGIN RET UNFIN.)
- 325 TL. EYE EXT. IMP.
- 326 T/S QUILL EXT. IMP.
- 327 NOT IN ATC START POSITION
- 329 CHUCKING SELECTION PROHIBITED
- 340 CONDITION No.1 MISSING
- 341 CONDITION No.2 MISSING
- 361 TAIL ALARM
- 365 CARRIER CONTROLER MALFUNCTION
- 366 SHIFTER CONTROLER MALFUNCTION
- 374 OPERATING SWITCH FAULT
- 375 MOTOR & SERVO TURNING OFF ERR.
- 376 MAIN POWER TURNING OFF MALFUNCTION
- 377 COOLANT LEVEL LOW
- 378 HIGH PRESSURE PUMP THERMAL TRIP
- 379 TANK PRESSURE LOW
- 381 CONDITION MISSING (SET UP SWITCH)
- 382 COOLANT SYSTEM MALF.
- 383 ATC ALM: CARRIER&SHIFT. POS. MALF.
- 385 START COND. ERR. (Z-AXIS POS.)
- 386 ATC STOP
- 390 TOOL ON INTERFER ALARM
- 391 LD/ULD/ACHG CONDITION ALARM
- 392 MAGAZINE MANUAL INTERR.
- 394 ATC CONTROLLER MALF.
- 395 CHECK SENSOR MALF. (SEE D199)
- 397 MAGAZINE DOOR INTERLOCK
- 398 MAGAZINE COVER OPEN
- 399 MAINTE./ADJUST PARAM. ON
