Milltronics Centurion 7 Error Messages complete list for cnc machinists programmers who work on Milltronics cnc machines
Contents
- Milltronics Error Messages
- 001 Invalid function number
- 002 File not found
- 003 Path not found
- 004 Too many open files
- 005 File access denied
- 006 Invalid file handle
- 007 Memory control blocks destroyed
- 008 Insufficient memory
- 009 Invalid memory block address
- 010 Invalid environment
- 011 Invalid format
- 012 Invalid file access code
- 013 Invalid data
- 015 Invalid drive specified
- 016 Cannot remove current directory
- 017 Cannot rename across drives
- 018 No more files
- 100 Disk read error
- 101 Disk write error – Parts memory is full
- 102 File not assigned
- 103 File not open
- 104 File not open for input
- 105 File not open for output
- 106 Invalid numeric format
- 150 Disk is write-protected
- 151 Unknown unit
- 152 Drive not ready
- 153 Unknown command
- 154 CRC error in data The disk being read is corrupted.
- 155 Bad drive request structure length
- 156 Disk seek error
- 157 Unknown media type
- 158 Sector not found
- 159 Printer out of paper
- 160 Device write fault
- 161 Device read fault
- 162 Hardware failure
- 163 Sharing Violation
- 200 Division by zero
- 201 Range check error
- 202 Stack overflow
- 203 Heap overflow – Insufficient RAM memory
- 204 Invalid pointer operation
- 205 Floating point overflow
- 206 Floating point underflow
- 207 Invalid floating point operation
- 208 TP Overlay Error
- 209 TP Overlay Error
- 210 TP Object Error
- 211 TP Object Error
- 212 TP Object Error
- 213 TP Object Error
- 214 TP Object Error
- 300 Program already exists
- 301 Invalid program number
- 302 No programs to select from
- 303 Problem saving program(s) to disk
- 304 Problem loading program(s) from disk
- 305 Not formatted for conversational. Try text editor.
- 306 Conversational system has been corrupted
- 307 Illegal event number
- 308 Invalid tool number
- 309 Can’t copy or rename a file to itself
- 310 File not formatted for conversational or parameters
- 311 Parameter file not valid
- 312 Insufficient parts storage
- 313 Insufficient storage for compression, unable to post the file
- 314 Insufficient storage, post has been aborted
- 315 Out of storage space on the floppy
- 316 Not enough storage to create a new file
- 317 Simulator allows only 15 events
- 319 Send file aborted
- 320 Invalid PLC program.
- 321 Error in program O.
- 322 or custom G code program not found.
- 323 or custom M code program not found.
- 324 Invalid path or program not found for M6 tool change macro.
- 400 Home required
- 401 X axis software limit overtravel
- 403 Z axis software limit overtravel
- 404 A axis software limit overtravel
- 405 B axis software limit overtravel
- 406 C axis software limit overtravel
- 407 X axis excess error condition
- 408 Y axis excess error condition
- 409 Z axis excess error condition
- 410 A axis excess error condition
- 411 B axis excess error condition
- 412 C axis excess error condition
- 413 Attempted to move into safe zone
- 415 Can’t establish DNC link while program is running
- 416 Out of position, arc end point is not on the arc
- 417 Can’t edit parameters while program is running
- 418 Controller Card Error
- 448 Air Pressure Error. Check air hose connection
- 449 ERROR 449: Emergency stop: Axis drive fault. Reset servo drives or power down.
- 450 ERROR 450: Emergency stop condition. Reset drives or press to clear this message.
- 451 Lube fault, Check Waylube Level
- 452 Tool not found in auto tool sequence
- 453 Tool pot not up during turret movement
- 454 Not at tool change position
- 455 ATC arm is not out, axis movement not allowed
- 456 Can’t process auto tool change after switching to manual
- 457 Move length too great for control (split into smaller moves)
- 458 X axis is in the manual mode. Push reset to enable it
- 459 Y axis is in the manual mode. Push reset to enable it
- 460 Feedrate too large for control.
- 500 Last softkey pressed is not supported at this time
- 501 Illegal address “#” encountered
- 502 Undefined canned cycle
- 503 Return without gosub
- 504 Coincident points, the start point and end point are the same on an arc without a center
- 505 Radius too small to span given points
- 507 After compensation, line to arc lacks intersection
- 509 After compensation, arcs lack intersection
- 515 Unexpected file size The control read a file that was not the correct size.
- 517 Parameter out of range
- 518 Illegal program statement
- 519 Feedrate out of range
- 520 Spindle speed out of range
- 521 Negative arc radius
- 522 Negative polar radius
- 523 Illegal tool number
- 524 Illegal radius number
- 525 Illegal length number
- 526 Invalid access code
- 527 Invalid access level
- 529 Duplicate address’ encountered
- 530 Colinear line to line in round corner
- 531 Colinear line to arc in round corner
- 532 Colinear arc to line in round corner
- 533 Colinear arc to arc in round corner
- 535 Chamfer length is < 0
- 536 Can’t chamfer and round the same corner
- 537 Can’t chamfer to or from arcs
- 538 Loop counter out of range
- 539 Dwell time out of range
- 540 Illegal dwell time “#” encountered
- 541 No axis moves are allowed on a G31 or G32 block
- 542 G30 Illegal return to reference parameter on G30 block
- 543 Illegal G10 statement
- 544 Too many digits in number
- 545 Illegal K value for number of holes
- 546 Nested calls or gosubs too deep
- 547 Comment not closed
- 549 Unrecognized G code
- 550 Bad numeric format
- 551 Multiple decimal points
- 552 Missing “]”
- 553 Missing “[“
- 554 Tangent function overflow
- 555 Missing “/”
- 556 Negative SQRT argument
- 557 Unknown function
- 560 Illegal relational operator
- 567 Unresolved call
- 568 Unresolved goto or gosub
- 569 The tool is too large to cut inside the arc “Compensated radius is too small”
- 570 The tool is too large to cut inside the arc “1st compensated radius in arc to arc is < 0”
- 571 The tool is too large to cut inside the arc “2nd compensated radius in arc to arc is < 0”
- 572 Pocket clear is not in a Start/End mill cycle
- 573 Round wall is not in a Start/End mill cycle
- 574 Round wall radius will not span 1st Z depth and final Z depth
- 575 Tapered wall is not in a Start/End mill cycle
- 576 Z increment is 0
- 577 Input statements must precede axes moves
- 578 Undefined text cycle
- 579 Compensated arcs do not intersect
- 580 Invalid floating point operation. The argument passed to the LN function was zero or negative.
- 581 Invalid floating point operation. The Operand passed to the “#” function was zero or negative
- 588 Can’t set tool offsets for tool #0
- 600 Can’t nest Start/End mill cycles -WHILE WEND loops-
- 601 Missing WHILE statement
- 602 Missing WEND statement
- 603 Program N#### does not exist
- 605 Can’t modify dry run status while program is running
- 606 Program N#### is empty
- 607 Can’t exit DNC run mode while program is running
- 608 ‘P’ expected in M98 block
- 609 G20/21 not allowed in DNC Fast
- 610 Position move required after this rotation
- 611 Feed must be specified in every block while inverse time mode is active.
- 666 Quill movement detected, reposition the quill to it’s original position.
- Digitizing Errors
- 801 Missing end of pick
- 802 Reversed scan segment
- 803 Missing end of scan
- 804 Reversed pick segment
- 805 Invalid probe setup
- 806 Scan origin expected
- 807 Probe file not found
- 808 Setup not selected
- 809 Bad Z limits encountered
- 810 Stuck digitizing probe
- 812 Input out of range
- 900 RS232 overrun error (The system sending data may not have the same baud rate as the CNC.)
- 901 RS232 parity error (The system sending data may not have the same parity as
- 902 RS232 framing error (Remote system and CNC may not have the same line settings or a loose cable.)
- 903 RS232 break detected (RS232 cable may be loose.)
- 950 Obsolete controller software for this system
- 951 Obsolete acroloop software for this system
- 952 Obsolete keyboard software for this system
- 953 Obsolete bit access for ncb controller.
- 954 Control not detected.
- 955 Interface not detected.
Note what just occurred and call for technical support. A call was made to a non-existent DOS function.
002 File not found
File name specified as OLD does not exist. Try MENU.
003 Path not found
The drive or subdirectory specified does not exist.
Check Config.sys for FILES=20.
The file may be read only or is on a write-protected disk.
The program being loaded is too large to fit into memory. A program being run or verified is too large to run in the control’s memory. Try DNC mode.
011 Invalid format
013 Invalid data
Drive specified does not exist.
018 No more files
100 Disk read error
An attempt was made to edit a file that has been corrupted in some way, perhaps loss of power while editing, or an error 101 occurred while editing. Try a different file to see if the problem is specific to one particular file. If this is the case, the program must be recreated.
Note: This error occurs when trying to edit conversational files that were created with SLS software.
To avoid this error, remove programs from memory when you are done using them (store on a floppy). Also, watch the amount of memory available as you are programming. Deleting some programs from the parts memory will free up space for additional programs.
Procedure to recover from ERROR 101
(Disk write error: Parts memory full)
Type in commands that are shown in CAPITAL letters, followed by the ENT key.
1) ENTER (C:/RAM should be displayed)
2) CD.. (change directory)
3) CD PARTS (change to the parts directory)
4) DIR (list PART files)
5) DEL O####(#### is your part number)
NOTE: You can recreate your O#### file from your conversational (P####) file by reposting it.<
6) Power the machine OFF, then ON again, to RESET the control. Use UTIL-FILES-ERASE to erase programs that are no longer needed.
NOTE: You can check how much parts memory is available by using UTIL-INFO to look at the information page.
103 File not open
Check the write protect tab on the floppy disk that is being used.
151 Unknown unit
152 Drive not ready
Check to see that there is a disk in the floppy drive.
153 Unknown command
156 Disk seek error
Check the cabling from the control to the floppy drive.
Improper format on the floppy disk. Try another disk or try reformatting the same disk. Verify that floppy cables are properly connected.
202 Stack overflow
Run the DOS command CHKDSK to determine the amount of RAM that is available on the system. If possible, unload unnecessary device drivers that are loaded on the PC before starting the CNC.
Steps to take to avoid ERROR 203
(Heap overflow: Insufficient RAM memory)
If text cycles or canned cycles are being loaded and not being used, turn them off. See PARMS-SETUP-MISC.
1) (F7) PARMS
2) (F9) CTRL
3) Move cursor to Load Text Cycles
4) Toggle to “No”
5) (ESC)
6) (ESC) to the main menu.
7) Power the machine OFF, then ON, again.
If you are running a large program, try running it through the RS-232 RUN mode.
210 TP Object Error
211 TP Object Error
212 TP Object Error
213 TP Object Error
214 TP Object Error
An attempt was made to use a program name already in use. Use a different name.
Valid program numbers are 1 through 9999.
* Simulator program numbers are 1 through 15.
This error may occur anytime a menu is being created for file selection when there are no files. There may be an unformatted disk in the floppy drive. Parts memory may be empty.
There is no floppy disk in the disk drive. The floppy disk may not have room to store additional files. There may be an unformatted disk in the drive.
Disk was removed from floppy drive after setting files.
Event number in conversational program is negative.
Tool number is less than zero or greater than 99.
Try using a different file name.
Problem receiving a file via RS-232. Check to see if the proper file was sent.
Problem receiving parameter file via RS-232. Check to see if the parameters were sent.
Parts memory is full. Try erasing some programs from the parts directory (UTILS-FILES-ERASE).
Program on floppy disk may be too large to fit into the control’s memory.
Erase some programs from the parts memory.
Floppy disk is full or has too many programs. There is a limit of 224 files that can be stored in the root directory on a floppy disk. A sub-directory can be created on the floppy disk and the floppy path changed to save files to the sub-directory. This allows full use of the disk space.
There is not enough parts space to create a new conversational program. Erase unnecessary programs to free up parts space.
One of the ACRO.HEX (or NCB.HEX) files in the RAM directory is corrupt.
A custom MCODE or customer GCODE has an error.
The tool change macro may have an error in it.
400 Home required
The machine must be homed before any axis movement can take place on the machine, i.e. MDI, JOG, HDW, etc.
These errors are a result of the axis reaching the programmed limits of travel.
When jogging or handwheeling and an axis limit is reached, the control will only allow movement in one direction.
In a program the error may be encountered. The G92 and/or G54 parameters may need to be modified.
Tool length offsets are also a potential cause of Z axis overtravel.
These errors are caused by the axis not being able to keep up with the programmed move at the programmed speed.
Does the error occur during rapid moves only? Y__ N__
If so, check bus voltage and rapid feed parameters.
Do any of the drive cards have red LED’s lit? Y__ N__
If so, which light on which card? VOL, GF, RMS, or SG
Other causes might be too heavy of a cut, worn tool, low ∀15 volts, accel/decel parameters, or drive card failure.
The program being run must be halted before the DNC link can be established.
The program must be halted before editing parameters.
Is the program in block mode or feedhold?
The float switch on the autolube pump is indicating that oil needs to be added to the autolube tank.
Check UTIL-TLCHG-SLOTS for that tool number.
Check to see if the POT UP switch is functioning as it should be.
Try commanding a G32 before the M6 command.
The character within quotes ” ” is not a valid address, such as X, Y, Z, R, G, etc. The block where the error occurred is shown in the block display. Check that block for the invalid address.
Refer to page 328, Section 5 about gosub and return.
The start point and end point are the same on an arc without a center.
Start and end points are more than “R” distance apart.
Parameter number is less than zero. For parameter numbers greater than 699 you must use data mode (G10, G11).
Command in program statement is not considered valid.
The programmed feedrate is beyond the “maximum feedrate” parameter value in the machine setup parameters. The program feedrate may be negative.
The programmed spindle speed is beyond the “spindle range” parameter in the machine setup parameters. The programmed spindle speed may be negative.
An attempt was made to generate a negative arc radius.
A polar radius must be specified as a positive value.
Valid T numbers are 0 – 99.
Valid D numbers are 0 – 99.
Valid H numbers are 0 – 99.
The access code does not match that which is loaded in the machine setup parameters.
Valid levels are 0 – 4.
The same address was found twice on the same block, such as X0 Y0 X.5.
Chamfer length must be a positive number.
Choose either chamfer or round corner.
The maximum number of loops for a call is 999.
Probably a negative number was specified. The maximum dwell time is 999999999 seconds.
Try G4 F##.####; specify X, P, or F after G4.
G31 and G32 are intended to move Z only. Relocate X and Y moves to another block.
Should be P2, P3, or P4 for second, third, and fourth reference point.
The number of digits used is beyond what the address is expecting. For example, G100 should only be two digits.
K must be a number between 1 and 1000.
Probably a program is calling itself. Nest limit is 50 for program calls.
Always use “( )” (parentheses) in pairs for program comments.
G code encountered is not recognized by the control.
Expecting a numeric value, or a parameter value enclosed within [ ], after an address X, Y, Z, R, etc.
Multiple decimal points were detected within one numeric value.
552 Missing “]”
Always use square brackets in pairs.
553 Missing “[“
Trying to find the tangent of a number close to 90Ε
555 Missing “/”
Arctan “ATAN” syntax is P## = ATAN[#/#].
567 Unresolved call
Program being called does not exist (Call ####).
N#### does not exist in the program (Goto ####).
Eliminate the arc, or use a smaller tool.
-WHILE WEND loop-
Use START at the beginning of the mill cycle and END at the end of the mill cycle.
-WHILE WEND loop-
-WHILE WEND loop-
Character specified in a text command is not supported.
Load Text Cycles parameter may not be set in PARMS-CTRL.
Do not start a mill cycle within a mill cycle.
May be an end mill cycle without a start mill cycle.
May be a start mill cycle without an end mill cycle.
Program being called as a subprogram does not exist. Check to see if the program called is in the memory.
Program must be halted before changing dry run status.
Try HALT-DRY-RESUME.
Text program being run or verified is empty. Try editing and reposting the conversational file.
The DNC mode must be halted before exiting.
Digitizing Errors
800 Illegal probe block
Syntax error in guidance file. Check the block format. Blocks must start with an X, Y, or Z which is to be followed by one or two P commands.
Pick boundary is not closed. Input file did not end with a pick boundary definition block.
Multiple scan segment started that would cause the scan direction to change in the middle of the current scan.
Pick segment terminated before the end of scan was defined. There should be at least two scan definition blocks between each pick boundary.
Multiple pick segment started that would cause a change in pick direction. Use multiple probe segments if this is the desired intention.
Input file does not start with a comment containing three asterisks. Also, the following three blocks should be X, Y, Z, or Y, X, Z depending on scan plane.
Multiple pick segment started without defining the start of the scans within that segment.
Could not find the selected input file.
Tried to probe without selecting both the input file and the output mode from the probe setup screen.
The max Z height is less than the max Z depth value.
Digitizing may have reached max Z height and part contact is still detected. If the probe is not actually touching the part, the probe may require maintenance. If it is touching the part, then the part has to be lowered or the max Z height should be increased.
Check RS-232 baud rate parameter in PARMS-CTRL.
the CNC.)
Check RS-232 parity parameter in PARMS-CTRL.
Check line settings in PARMS-CTRL for baud rate, parity, and stop bits.
Check cabling and connectors for good contact.
