Submit by: Brian
Drawing/Image
CNC Program
0 BEGIN PGM 10130 MM 1 BLK FORM 0.1 Z X+0 Y+0 Z-20 2 BLK FORM 0.2 X+120 Y+70 Z+0 3 TOOL DEF 1 4 TOOL DEF 2 5 TOOL DEF 3 6 TOOL CALL 1 Z S500 7 L M6 8 L M13 9 CYCL DEF 1.0 PECKING 10 CYCL DEF 1.1 SET UP 2 11 CYCL DEF 1.2 DEPTH -2 12 CYCL DEF 1.3 PECKG -2 13 CYCL DEF 1.4 DWELL 0 14 CYCL DEF 1.5 F200 15 CALL LBL 2 16 TOOL CALL 2 Z S1000 17 L M6 18 L M13 19 CYCL DEF 1.0 PECKING 20 CYCL DEF 1.1 SET UP 2 21 CYCL DEF 1.2 DEPTH -20 22 CYCL DEF 1.3 PECKG -10 23 CYCL DEF 1.4 DWELL 0 24 CYCL DEF 1.5 F200 25 CALL LBL 2 26 TOOL CALL 3 Z S500 27 L M6 28 L M13 29 CYCL DEF 2.0 TAPPING 30 CYCL DEF 2.1 SET UP 2 31 CYCL DEF 2.2 DEPTH -20 32 CYCL DEF 2.3 DWELL 0 33 CYCL DEF 2.4 F50 34 CALL LBL 2 35 L M30 36 LBL 2 37 CYCL DEF 220 POLAR PATTERN Q216 = 30 ;CENTRE IN 1ST AXIS Q217 = 35 ;CENTER IN 2ND AXIS Q244 = 36 ;PITCH CIRCLE DIAMETR Q245 = 0 ;STARTING ANGLE Q246 = 360 ;STOPPING ANGLE Q247 = 0 ;STEPPING ANGLE Q241 = 8 ;NR OF REPETITIONS Q200 = 2 ;SET-UP CLEARANCE Q203 = 0 ;SURFACE COORDINATE Q204 = 100 ;2ND SET-UP CLEARANCE 38 CYCL DEF 220 POLAR PATTERN Q216 = 85 ;CENTRE IN 1ST AXIS Q217 = 35 ;CENTER IN 2ND AXIS Q244 = 36 ;PITCH CIRCLE DIAMETR Q245 = 0 ;STARTING ANGLE Q246 = 360 ;STOPPING ANGLE Q247 = 0 ;STEPPING ANGLE Q241 = 8 ;NR OF REPETITIONS Q200 = 2 ;SET-UP CLEARANCE Q203 = 0 ;SURFACE COORDINATE Q204 = 100 ;2ND SET-UP CLEARANCE 39 LBL 0 40 END PGM 10130 MM
