NUM 1020/1040/1060T M-code list for cnc machinists who work on cnc lathe machines with NUM 1020/1040/1060T CNC controls.
NUM 1020/1040/1060M M-Codes
M-Code | Description |
M00 | Programme stop |
M01 | Optional stop |
M02 | End of programme |
M03 | Clockwise spindle rotation |
M04 | Counterclockwise spindle rotation |
M05 | Spindle stop |
M06 | Tool change |
M07 | Coolant 2 on |
M08 | Coolant 1 on |
M09 | Coolant off |
M10 | Clamp |
M11 | Unclamp |
M12 | Programmed feed stop |
M19 | Spindle index |
M40 to M45 | Spindle speed ranges |
M48 | Enable overrides |
M49 | Disable overrides |
M61 | Release of current spindle in the axis group |
M62 to M65 | Control of spindles 1 to 4 |
M66 to M69 | Measurement of spindles 1 to 4 |
M997 | Forced block sequencing |
M998 | Reactivation of edit (EDIT) and manual data input (MDI) modes and subroutine calls by the automatic control function |
M999 | Programmed cancellation of the edit (EDIT) and manual data input (MDI) modes and subroutine calls by the automatic control function |
