Submit by: BEATA
Summary
NUM CNC mill program example which shows the working of many NUM Cycles like G45 Simple Pocket cycle etc.
Following NUM G-Codes Cycles are used in this cnc program example
G45 Simple pocket cycle
G71 Metric data input
G81 Centre drilling cycle
G80 Canned cycle cancel
G87 Drilling cycle with chip breaking
G84 Tapping cycle
G52 Programming of movements in absoluted dimensions with reference to the measurement origin
Drawing/Image
CNC Program
%3354 (Exemple de cycles en fraisage) N10 G90 G80 G71 G40 N20 G0 G52 Z0 (CENTRAGE) N30 T8 D8 M6 N40 G97 S1670 N50 G0 X-34 Y-25.98 Z10 N60 G0 Z4 M3 M41 N70 G81 Z-5 F117 N80 X-15 Y-25.98 N90 G80 G00 Z10 M9 M5 N100 G0 G52 Z0 (PERCAGE) N110 T7 D7 M6 (FORET D6.75) N120 G97 S1085 N130 G0 X-34 Y-25.98 Z10 N140 G0 Z4 M3 M40 M8 N150 G87 Z-14 P5 ES2 Q3 EP2 F87 N160 X-15 Y-25.98 N170 G80 G0 Z10 M9 M5 N180 G52 Z0 (TARAUDAGE) N190 T10 D10 M6 (TARAUD M8) N200 G97 S384 N210 G0 X-34 Y-25.98 Z10 N220 G0 Z4 M3 M40 M8 N230 G84 Z-10 K1.25 N240 X-15 Y-25.98 N250 G80 G00 Z10 M9 M5 N260 G52 Z0 (USINAGE DE LA POCHE) N270 T4 D4 M6 (FRAISE A RAINURER D8) N200 G97 S1034 N210 G0 X8 Y0 Z10 N220 M3 M40 M8 N230 G45 X0 Y0 Z7.16 ER4 EX30.96 EY19 EB8 P2 Q6 I0.5 J0.5 EP83 EQ259 EI52 EJ165 N240 G0 G52 Z0 M5 M9 N250 M2
