Okuma Alarm-D 4058 Previous backup error
NC started up using the data in the backup memory, which is backing up periodically since NC time shut down abnormally.
XXXXYYYY
XXXX
bit0: SPARE
bit1: HD backup status file
bit2: Low speed NC backup data file
bit3: High speed NC backup data file
bit4: PLC backup data file
bit5: PLC-HMI data file
bit6: Alarm history data file
bit7: PLC axis data file
bit8: POT TOOL data file
bit9: MOP TOOL Tool data file (M/C only)
bit10: MOP TOOL Parameter file (M/C only)
bit11: Thermal deviation compensation data file
YYYY
1: File read open error
2: File read error
3: Version check error
4: Check sum error
5: Double check sum error
6: Backup memory check error
7: File write open error
8: File write error
