Okuma Alarm-D 4064 Awaiting establishment of DeviceNet
Wait the establishment of DeviceNet.
CH* SC$
*: Channel number where the error occurred
$: Sequence counter
XXYYZZZZ
XX:Slave station MacID where the error occurred
YY:Slave station XX error status
0x00:Normal or nonexistent slave station
0x46:Duplicate MacID error
0x48:Communication stop
0x49:Discrimination information was not compatible with scan list
0x4D:Data size was not compatible with scan list
0x4E:No response in the connection check
0x4F:Other slave stations are nonexistence on network
0x50:Idle condition
0x53:Error received in the connection check
0x54:Timeout occurred in the connection check
0x56:Turn into the idle mode
0x5B:Bus off
0x5C:Network power supply off
(XXYY become 0xFFFF, if its not caused by slave station, such as communication delay. )
ZZZZ: Scanner error status
bit0 :Memory check error (when memory initialized)
bit1 :Scan list initialize error
bit2 :Scan list mismatch error (MacID)
bit3 :Scan list mismatch error (Input data)
bit4 :Scan list mismatch error (Output data)
bit5 :Duplicate MacID error
bit6 :Network power supply status error
bit7 :Memory parity error
bit8 :Input data reception error (single)
bit9 :Input data reception error (double)
bit10:Output data transmission error (single)
bit11:Output data transmission error (double)
bit12:Slave station communication delay error (single)
bit13:Slave station communication delay error (double)
bit14:Bus off
bit15:Diagnostic information access error
1)Hardware failure
2)Software failure
