Okuma Alarm-D 4069 Turret index sequence has not ended.
It instructed in the manual axis feed (JOG/PH etc.) with the turret index sequence had not ended.
It is not possible to instruct in the manual axis feed (JOG/PH etc.) if the turret index sequence doesn’t end.
Character string
XXXXYYYY
“XXXX” shows the manual H1 turret index sequence counter (WU1528).
“YYYY” shows the automatic A turret index sequence counter (WU269) or the automatic B turret index sequence counter (WU339).
Expected faulty point
The turret index sequence of the clamping operation etc. might not ended though the index is completed in externals.
Treatment measures
Please instruct in the axis movement again after it waits for a while. Please inquire of our service if the same alarm is generated.
