Okuma Alarm-D 4070 Solid model position error
Because the positions of solid model cannot be confirmed, the Collision detection cannot be done.
XXYY
“XX” shows the kind of the solid model.
01-> Touch setter
02-> Tailstock centor
03-> Parts catcher
04-> Tow-arong type tailstock is never connected.
05-> M axis angle
06-> When the multi-edged tool is installed, M axis not positioned 30-degree pitch or 45-degree pitch.
( It allows it up to the error margin of 0.5 degrees.)
07-> When the sequence return cycle, the interference check demand of T, M operation from PLC is abnormal.
08-> Steady rest relieving.
10-> Tow-along type Steady rest is never connected.
11-> Protection cover for fixed touch setter.
12-> Tool breakage detection sensor
13-> ATC shutter
14->Attachment stocker shutter
15-> Steady rest arm
In YY, two or more solid models are the sequential numbers for the situation.
Expected faulty point
Solid model specify the position with the confirmation device such as the limit switches.
In the state of the movement’s of solid models that became the alarms interrupting or the disconnection of wiring are thought.
Moreover,In case of code =401,it never connects it with Z axis in Tow-along tailstock. Moreover, In case of code = 501,M axis positioning is not completed. Moreover, In case of code = 601,when the multi-edged tool is installed,M axis not positioned 30-degree pitch or 45-degree pitch
(It allows it up to the error margin of 0.5 degrees.)
Treatment measures
When the movement of the solid model is interrupted, it executes it to the last minute.
Still, when this alarm is generated, wiring is examined.
TIn case of code =401 the position is not fixed if it doesn’t connect it with Z axis for Tow-along tailstock. Please do connected operation with Z axis.
Please do the M axis index in code = 501 or 601.
In case of code =701,Please do the restart operation again after NC reset. Please inquire of our service if the phenomenon relapses.
