Okuma Alarm-D 4107 Awaiting CAS check result
“Block execution Waiting” was generated because the interference detection processing had not ended in the block on the way in consecutive cutting feed blocks.
Character string
Waiting frequency.(Unit:8msec. It is shown that waiting for 16msec was generated when the code was “2”.)
Expected faulty point
The material model and the shape of the tool are complex, and it takes the interference check processing time long.
Or, when the block continues a short line immediately after the block of the look-ahead prohibition,it is thought.
Treatment measures
It thinks the interference check processing time is shortened (simplify model of work & tool) when there is an influence on the cutting face by generating the interference result waiting.
Still, the interference check is made not to process by using M867 (interference check switching off), M866 (with interference check), G99 ( interference check and shaving off is invalid), and G98 ( interference check shaving off is effective) when not improved.However because the interference check is not done, it is necessary to confirm no interference before it processes it in this case.
