Okuma Alarm-D 4173 MCS Motor overheat
The motor temperature is abnormally high.
Axis name or none (spindle)
YYYYZZZZ
YYYY = 0 (fixed)
ZZZZ = 0010: Motor overheat
ZZZZ = 0011: Motor overheat is detected at the motor.
ZZZZ = 0012: Motor overheat is detected at the position encoder.
ZZZZ = 0013: Motor overheat is detected at the motor and the encoder.
– Malfunction of VAC motor fan, dirty heat sink, CW/CCW turns and stops at high frequency
– BL motor
– Motor encoder (BL motor detects overheat by its encoder.)
