Okuma Alarm-D 4200 Reboot enabled parameter set
A parameter which requires to turn on power to make it effective is designated.
Operation Example:The alarm lamp lights up when the parameters related with RS232C are set.
After backup-copy of the parameter data using the function key, turn off the power and then turn it on.
