Okuma Alarm-D 4209 Hi-CUT Pro parameter out of range (replacing)
Hi CUT Pro control parameter is out of the setting range, and therefore such parameter values are internally replaced with the valid data.
This alarm appears while the replaced parameter is effective.
Index
The parameter value specified in G265 block exceeds the effective range.
Specify appropriate parameter value in the G265 command.
