Okuma Alarm-D 4211 SPM parameter out of range (replacing)
SPM control parameter value is out of range and is overridden internally so as to set back within the range. This message is displayed while the overridden parameter is active.
(Super Precision Machining (SPM) control = Hi-Cut Pro or Super-NURBS)
A specified parameter value exceeds the valid range in a G265 block.
Parameter value set as (Shape Reconstruction) Minimum Block Length is greater than that set as (Shape Reconstruction) Maximum Block Length.
Specify a proper parameter value in the G265 command block.
Correct the parameter values so that (Shape Reconstruction) Minimum Block Length is smaller than or equal to (Shape Reconstruction) Maximum Block Length.
