Okuma Alarm-D 4221 Communication procedure TTD
TTD is received for consecutive RC3 + 1 times during communication procedures.
1)Defective RS232C interface
2)Defective hardware or software of the host computer
3)Mismatch between the actual communication line specification (baud rate, code configuration, etc.) and the communication set by the communication parameters.
1)Check the hardware and software of the host computer.
2)Change the FRP board or RPP board channel to other channel by setting proper data at communication parameter.
Change the connection of the connector to the proper position,accordingly.
3)Check the following communication specifications between the actual communication line specification and the communication
parameters:
RS232C interface channel being used
Parity
Number of stop bits
Transmission code
Baud rate
Use of WACK/TTD control
Effective/ineffective transparent mode
Related Specifications
DNC-C
