Okuma Alarm-D 4224 Canceling stroke end limit
It entered a stroke end limit cancel state being met all the following requirements.
-condition
1)The touch setter measurement function is effective.
2)Manual driving mode inside.
3)Touch setter sensor head advancement state.
4)The code that “The stroke end limit can be canceled” of PLC has been turned on.
A mechanical model isn’t defined inside the ATC shutter in CAS, so please be careful about intervention sufficiently and operate.
1->It entered a stroke end limit cancel state being met all the above-mentioned requirements.
