Okuma Alarm-D 4228 SSynchronized rotation speed over
In the main and M-tool spindle synchronized rotation mode (when any of M221, M222, M223, M224, M225, and M226 is active), an attempt is made to rotate the main spindle at a speed higher than the M-tool spindle allowable speed.
In Hob Cutting Synchronous mode, an attempt is made to rotate the M-tool spindle at a speed higher than the main spindle allowable speed.
1->In the main and M-tool spindle synchronized rotation mode, an attempt is made to rotate the main spindle at a speed higher than the M-tool spindle allowable speed.
3->In Hob Cutting Synchronous mode, an attempt is made to rotat the M-tool spindle at a speed higher than the main spindle allowable speed.
Program error
Select the main spindle speed taking the allowable speed of the main and sub spindle in to consideration.
Select the M-tool spindle speed taking the allowable speed of the main and sub spindle in to consideration.
