Okuma Alarm-D 4304 No axis movement after offset change
This warining ocuurs axis moving command after change any offset, when you select parameter of “Move only axis for order”.
Character
YYXX
XX: A turret information
bit0: Z-axis
bit1: X-axis
bit2: C-axis
bit3: W-axis
bit4: Y-axis
bit5: B-axis
bit1: X-axis
bit2: C-axis
bit3: W-axis
bit4: Y-axis
bit5: B-axis
YY: B turret information
bit0: Z-axis
bit1: X-axis
bit2: C-axis
bit3: W-axis
bit1: X-axis
bit2: C-axis
bit3: W-axis
The axis is not ordered.
Add the axis positioning command for warning.
