Okuma Alarm-D 4306 Turret movement decelerating
In the interference detection function between turrets of two saddle machine,the turret is moving the turret interference deceleration area at the rapid feed speed.
While the rectangular shape of B turret projected to the XZ plane is interfering with the shape to gives the room of 50mm (NC Optional Parameter Word Data No.95) to the rectangular shape of A turret projected to the XZ plane, this alarm is displayed, and the rapid feed speed is limited to 1m/min or less.
Character string
none
1
Expected faulty point
Mistake of NC program instruction
Treatment measures
Please confirm the NC program on A saddle side and B saddle side of the part where the alarm is generated.
It is likely to actually become this alarm even if there is considerably room, because this alarm detects interference by the rectangular approximation shape of the XZ plane for safety.
In that case, adjust the amount of room (NC Optional parameter word No.95 unit: mm).
Or, it instructs the part where this alarm is generated in M867 (CAS function release).
Then, this alarm is not detected.
However, please drive in that case after it confirms it enough.
