Okuma Alarm-D 4308 X-axis over limit
When machining mode command (G270-2) was ordered, there is not X-axis in plus variable limit.
When machining mode command (G270-2) was ordered, there is not the X-axis in plus variable limit.
If the following conditions can confirm, you can restart the cutting program by “interlock cancel” + “NC start”.
– A turret moves to Y-axis direction and does not interfere it.
If interference is confirmed, please order it again after moving to the position where I do not interfere.
