Okuma Alarm-D 4347 TDC invalid
The thermal deformation compensation state is “off”.
The thermal deformation compensation is turned off to set the user input parameter.
Or, the thermal deformation compensation is turned off because M990 command is issued.
Index
X
X=1-> The thermal deformation compensation is turned off by using the user input parameter on the parameter setting screen.
X=2-> The thermal deformation compensation is turned off by issuing M990 command.
