Okuma Alarm-D 4702 Cycle start interlock
with Loader/Robot Interface B, C, or D; with Loader/Robot
Interlock: Loader/Robot at WaitingPosition Code is Off.
NC Loader: Loader inside Lathe Code is On.
None->above
1->Start Key is pressed; when Traverse Override is Not 100[%].
2->Start Key is pressed; when Spindle Override is Not 100[%].
3->Start Key is pressed; when Chip Conveyer Operation Mode is Not Auto Mode.
4->Start Key is pressed; when Steady Rest was not Retraction.
5->Start Key(both hands cycle start contain)is pressed; when it was not door interlock SW ‘OFF’ and an automatic operation mode and front door ‘close’.
6->Start Key is pressed; When it was not an automatic operation mode and front door ‘close’.
7->When there was work on work piece stand, cycle start was about to done.
8->Though a program selection number and a switch input program number were mismatches, cycle start was about to be done.
9->They went along cycle start in cycle start button of option panel at the time of door interlock OFF.
10->Concerning the tailstock ABSO encoder specification, positioning number (output of program command) and positioning number (input from encoder controller) are mismatches
11->An NC start command was issued with the door open (for manual front door types).
12->An NC start command was externally issued.
13->An attempt was made to start with a cycle start command from the robot with the operation panel not at the retract position.
14->An attempt was made to start the NC unit when a start disable signal was sent from the chip conveyor.
15->The machine was started in AUTO mode with the ALL ORIGIN lamp not lit.
16->The program was started when the quality check counter had counted up.
17->The program was started when the end of tool life had been reached.
18->The machine was started with adapted control data with the front door open, regardless of the door interlock ON/OFF status.
19->An attempt was made to start the program with a workpiece at the output side (operator’s side) of the work rest.
20->An attempt was made to start the NC unit with the standard START key, external start signal, or cycle start command with the operation panel not fully stored.
21->An attempt was made to start with the operation mode switch set to CONTINUOUS and any of the following conditions not met: ALL ORIGIN (green) lamp ON, chip conveyor linked, dust collector linked, and machine under continuous operation signal ON.
22->An attempt was made to start with the operation mode switch set to 1 CYCLE and either of the following conditions not met: chip conveyor linked and dust collector linked.
23->An attempt was made to start with the operation mode switch set to 1 CYCLE and with no unmachined workpiece.
24->The machine program was started with the machine setup switch ON.
25->The program was started without quality check.
26->Start Key is pressed; when Cut off rod was not Retraction.
27->Start Key is pressed; when Parts catcher was not Retraction.
28->Spindle rotation command is issued, when it was not a test mode and front door ‘close’.
29->The machine was started when machine was not home position.
30->At the specification of dual palm cycle start with a door close, it was let go off either button during close the door.
31->Start Key is pressed; when the air pressure switch is not ON.
32->Start Key is pressed, when the work remove confirmation switch is not ON.
33->Remain the workpiece in the work-out bucket.
34->An NC start command was issued with the door interlock OFF.
35->When the portable pulse-handle was connected, cycle start was about to done.
36->When the macihe was Single Cycle Mode and Single Block ON, cycle start was about to done.
37->When the macihe was Memory Run Mode and Single Block OFF, cycle start was about to done.
38->When the X/Z axis was not puls, cycle start was about to done.
39->Loader is automatic operating
40->When the Machine was not home position, cycle start was about to done.
41->A NC start command by ineffective NC start switch was issued.
42->A NC start command was issued without unclamping a work after program end.
43->Cycle start command in Single Cycle Mode is issued when Loader ON or Manual hatch is open.
44->NC start command in Single Cycle Mode or MEM Mode is issued when waiting for work check.
45->Conditions of Warm up run are satisfied.
46->A NC start command was issued when the chuck not clamped.
47->A NC start command was issued when the area sensor shaded.
48->When a chip pan cover is not close status, cycle start was about to done.
49->An attempt was made to start with a cycle start command from the robot/loader with the cycle ready signal OFF.
50->Front door or Side cover or Safety guard is open.
51->Touch setter start up button was pressed when touch setter is not advance position.
52->NC start up button was pressed when touch setter is not retract position.
53->Start Key is pressed, when either switch of “Tool change mode” or “Check mode” or “Maintenance mode” is ON.
54->Start Key is pressed, when the machine panel editing is possible.
55->On the APC interface type C specifications, the Synchronized Peripherals at Waiting Position Code is off.
56->NC start up button was pushed when Sub-spindle chuck was not unclamp or chucking miss PS was ON.
57->The program was started in the automatic operational mode when the start interlock signal is off.
58->Start key is pressed when portable pulse handle is used.
59->On the machine with manual grind mode specification, start Key was pressed, when manual grind mode was selected.
60->The 1st spindle encorder did not read a marker signal after power on.
61->The 2nd spindle encorder did not read a marker signal after power on.
62->Selection of ejector drill or tailstock; The state of the selecting switch and the confirmation signal is not corresponding.
63->A NC start command was issued when the portable pulse-handle was in use.
