Okuma Alarm-D 4706 Canceling door interlock
The door interlock cancel effect
1->On the machine with CE marking specifications, the door interlock release switch is turned on.
or M209 (door interlock release) command has been given.
2->The door interlock switch is OFF(interlock cancel effect).
The single block is ON.
3->The door interlock switch is OFF(interlock cancel effect).
1->Turn off the door interlock release switch
or specify M208 (door interlock release cancel).
2,3->The door interlock switch is turned ON.
