Okuma G75 C-chamfering
Okuma G75 G Code is used to chamfer a sharp edge.
  • G75 is effective only in the G01 mode.
  • G75 is non-modal and active only in the commanded block.
Okuma G75 Programming
G75 X Z L
ParameterDescription
X, ZIntersection point coordinates.
LSize of chamfered face. The sign is determined by the direction of axis movement; “+” when the Z-axis (X-axis) moves in the positive direction after X-axis (Z-axis) motion. “-” when the Z-axis (X-axis) moves in the negative direction after X-axis (Z-axis) motion.
Okuma G75 Example Program
N101 G01 X60 Z92 F0.1
N102 G75 Z60 F0.05 L3
N103 G75 X100 L-2
N104 G75 Z40 L4
N105 G75 X160 L-5
N106 Z10
Automatic Any-Angle Chamfering
If chamfering is required on edges having an angle other than 90°, Automatic chamfering function can be used to program chamfering easily.
Example Program
Okuma Automatic Any-Angle Chamfering G75
N100 G00 X20 Z120
N110 G75 G01 X60 L6 F0.1
N120 G75 Z90 L5
N130 G75 A120 X100 L6
N140 Z30
