Complete Okuma Lathe G and M Codes list for cnc machinists who work on Okuma cnc lathe machines.
Okuma CNC Lathe OSP-P200L
Okuma Lathe G Codes
G Code | Description |
G00 | Positioning |
G01 | Linear Interpolation |
G02 | Circular Interpolation (CW) |
G03 | Circular Interpolation (CCW) |
G04 | Dwell |
G20 | Home Position Command |
G21 | ATC Home Position Command |
G22 | Torque skip command |
G28 | Torque Limit command cancel |
G29 | Torque Limit command |
G30 | Skip cycle |
G31 | Fixed thread cutting cycle: Longitudinal |
G32 | Fixed thread cutting cycle: End Phase |
G33 | Fixed thread cutting cycle |
G34 | Variable lead thread cutting cycle: Increasing lead |
G35 | Variable lead thread cutting cycle: Decreasing lead |
G36 | Machine spindle-feed rod synchronized feeding (forward) |
G37 | Machine spindle-feed rod synchronized feeding (reverse) |
G40 | Tool Nose Radius Compensation: CANCEL |
G41 | Tool Nose Radius Compensation: LEFT |
G42 | Tool Nose Radius Compensation: RIGHT |
G50 | Zero Offset. Maximum Spindle Speed Designation G62 Mirror image designation |
G64 | Mirror image control OFF |
G65 | Mirror image control ON |
G71 | Compound Fixed Thread Cutting Cycle: Transverse |
G72 | Compound Fixed Thread Cutting Cycle: Longitudinal |
G73 | Longitudinal Grooving Compound Fixed Cycle |
G74 | Transverse Grooving Compound Fixed Cycle |
G75 | Automatic Chamfering |
G76 | Automatic Rounding |
G77 | Tapping compound fixed cycle |
G78 | Tapping cycle reversed thread |
G80 | End of Shape Designation (LAP) |
G81 | Start of Longitudinal Shape Designation (LAP) |
G82 | Start of Transverse Shape designation (LAP) |
G83 | Start of Blank material shape definition (LAP) |
G84 | Change of cutting conditions in bar turning cycle (LAP) |
G85 | Call of Rough Bar Turning Cycle (LAP) |
G86 | Call of Rough copy Turning Cycle (LAP) |
G87 | Call Finish Turning Cycle (LAP) |
G88 | Call of continuous thread cutting cycle (LAP) |
G90 | Absolute Programming |
G91 | Incremental Programming |
G94 | Feed Per Minute Mode (MM.MIN) |
G95 | Feed Per Revolution Mode (MM/REV) |
G96 | Constant Cutting Speed “ON” |
G97 | Constant Cutting Speed “OFF” |
G101 | Linear Interpolation in Contour Generation |
G102 | Circular Interpolation in Contour Generation (FACE) (CW) M |
G103 | Circular Interpolation in Contour Generation (FACE) (CCW) |
G110 | Constant speed cutting on turret A |
G112 | Circular thread cutting CW |
G113 | Circular thread cutting CCW |
G132 | Circular Interpolation in Contour Generation (SIDE) (CW) |
G133 | Circular Interpolation in Contour Generation (SIDE) (CCW) |
G136 | End of Coordinate System Conversion or Y-Axis Mode OFF |
G137 | Start of Coordinate System Conversion or Y-Axis Mode OFF |
G140 | Designation of Machining Mode Using Main Spindle |
G141 | Designation of Machining Mode Using Sub Spindle |
G161-G170 | G-code macro function MODIN |
G171 | G-code macro function CALL |
G178 | Synchronized tapping cycle (forward) |
G179 | Synchronized tapping cycle (reverse) |
G180 | Machine Compound Fixed Cycle: CANCEL |
G181 | Machine Compound Fixed Cycle: DRILLING |
G182 | Machine Compound Fixed Cycle: BORING |
G183 | Machine Compound Fixed Cycle: DEEP HOLE DRILLING |
G184 | Machine Compound Fixed Cycle: TAPPING |
G185 | Machine Compound Fixed Cycle: LONGITUDINAL THREAD CUTTING |
G186 | Machine Compound Fixed Cycle: END FACE THREAD CUTTING |
G187 | Machine Compound Fixed Cycle: LONGITUDINAL STRAIGHT THREAD CUTTING |
G188 | Machine Compound Fixed Cycle: TRANSVERSE STRAIGHT THREAD CUTTING |
G189 | Machine Compound Fixed Cycle: REAMING/BORING |
G190 | Machine Compound Fixed Cycle: KEYWAY CUTTING CYCLE |
G191 | Machine Compound Fixed Cycle: LONGITUDINAL KEYWAY CUTTING CYCLE |
Okuma Lathe M Codes
M Code | Description |
M00 | Program Stop |
M01 | Optional Stop |
M02 | End of Program |
M03 | Spindle CW |
M04 | Spindle CCW |
M05 | Spindle Stop |
M06 | Tool Change |
M08 | Coolant ON |
M09 | Coolant OFF |
M12 | Machine Spindle STOP |
M13 | Machine Spindle CW |
M14 | Machine Spindle CCW |
M15 | C-Axis Positioning |
M16 | C-Axis Positioning (NEG) |
M17 | CEJ MATIC :Request of Data transfer |
M18 | Post-process Gauging RS232C: Request of Data transfer |
M19 | Oriented Spindle Stop |
M20 | Tailstock Barrier OFF or spindle interference monitoring OFF (opposed two-spindle models) |
M21 | Tailstock Barrier ON or spindle interference monitoring ON (opposed two-spindle models) |
M22 | Chamfer OFF |
M23 | Chamfer ON |
M24 | Chuck Barrier OFF, Tool interference OFF |
M25 | Chuck Barrier ON, Tool interference ON |
M26 | Thread Lead Along Z-Axis |
M27 | Thread Lead Along X-Axis |
M28 | Tool Interference Check Function OFF |
M29 | Tool Interference Check Function ON |
M30 | End of Program |
M32 | Straight In-feed along thread face mode (on left face) |
M33 | Zigzag in feed in Thread Cutting |
M34 | Straight In-feed along thread face mode (on right face) |
M40 | Spindle gear Range Neutral |
M41 | Spindle Gear Range 1 |
M42 | Spindle Gear Range 2 |
M48 | Spindle Speed Override Ignore Cancel |
M49 | Spindle Speed Override Ignore |
M55 | Tailstock Spindle Retract |
M56 | Tailstock Spindle Advanced |
M58 | Chucking Pressure Low |
M59 | Chucking Pressure High |
M72 | ATC Unit Position at Approach Position |
M73 | Thread Cutting Pattern 1 |
M74 | Thread Cutting Pattern 2 |
M75 | Thread Cutting Pattern 3 |
M76 | Parts Catcher Retract |
M77 | Parts Catcher Advanced |
M78 | Steady Rest Unclamp |
M79 | Steady Rest Clamp |
M80 | over cut Advanced |
M81 | over cut Retract |
M83 | Chuck Clamp |
M84 | Chuck Unclamp |
M85 | No Return to the Cutting Starting Point after the completion of rough turning cycle (LAP) |
M86 | Turret Indexing direction: CW (reverse) |
M87 | Cancel of M86 |
M98 | Tailstock Spindle Thrust Low |
M99 | Tailstock Spindle Thrust High |
M109 | Cancel of M110 |
M110 | C-Axis Joint |
M134 | Z-Axis Thrust Monitoring OFF |
M135 | Z-Axis Thrust Monitoring ON |
M136 | Designation of Multiple fixed cycle configuration |
M137 | Touch setter interlock release ON |
M138 | Touch setter interlock release OFF |
M139 | Lead Machining Function – Learning Operation |
M140 | Tapping Cycle M-Tool Constant Rotation Answer Ignored |
M141 | C-Axis Clamp or not Selection |
M142 | Coolant Pressure Low |
M143 | Coolant Pressure High |
M146 | C-Axis Unclamp |
M147 | C-Axis Clamp |
M152 | M-Tools Spindle Interlock ON |
M153 | M-Tools Spindle Interlock OFF |
M161 | Feedrate Override Fix (100%) |
M162 | Cancel of M163 |
M163 | M-Tools Spindle Speed Override Fix (100%) |
M168 | Ignoring M-Tool Spindle Constant Speed Answer |
M169 | C-Axis NoClamp |
M191 | M-Tool Spindle Orientation Direction Specified CW |
M192 | M-Tool Spindle Orientation Direction Specified CCW |
M197 | Thread Cutting Phasing Stroke Clear |
M211 | Keyway Cutting Style: Minus Direction |
M212 | Keyway Cutting Style: Zigzag |
M213 | Keyway Cutting Style: Designated Depth Infeed |
M214 | Keyway Cutting Style: Equal Depth Infeed |
