Osai 10 Series CNC G Codes for Mill & Grinding complete list.
Osai 10 Series CNC G Codes – Mill & Grinding
G Code | Description |
G00 | Rapid axes positioning |
G01 | Linear interpolation |
G02 | Circular interpolation CW |
G03 | Circular interpolation CCW |
G04 | Dwell at end of block |
G09 | Deceleration at end of block |
G16 | Circular interpolation and cutter diameter compensation on a defined plane |
G17 | Circular interpolation and cutter diameter compensation on 1st-2nd axes plane |
G18 | Circular interpolation and cutter diameter compensation on 3rd-1st axes plane |
G19 | Circular interpolation and cutter diameter compensation on 2nd-3rd axes plane |
G20 | Closes GTL profile |
G21 | Opens GTL profile |
G27 | Continuous sequence operation with automatic speed reduction on corners |
G28 | Continuous sequence operation without speed reduction on corners |
G29 | Point-to-point operation |
G33 | Constant or variable pitch thread |
G40 | Cutter diameter compensation disable |
G41 | Cutter diameter compensation-tool left |
G42 | Cutter diameter compensation-tool right |
G60 | Closes the HSM profile |
G61 | Opens the HSM profile |
G62 | Splits the HSM profile in two with continuity |
G63 | Splits the HSM profile in tw with link |
G66 | Splits the HSM profile in two with edge |
G67 | Splits the HSM profile in two with reduced speed on edge |
G70 | Programming in inches |
G71 | Programming in millimetres |
G72 | Point probing with probe tip radius compensation |
G73 | Hole probing with probe tip radius compensation |
G74 | Probing for theoretical deviation from a point without probe tip radius compensation |
G79 | Programming referred to axis home switch |
G80 | Disable canned cycles |
G81 | Drilling cycle |
G82 | Spot-facing cycle |
G83 | Deep hole drilling cycle |
G84 | Tapping cycle |
G85 | Reaming cycle |
G86 | Boring cycle |
G89 | Boring cycle with dwell |
G90 | Absolute programming |
G91 | Incremental programming |
G92 | Axis presetting without mirror |
G93 | Inverse time (V/D) feedrate programming mode |
G94 | Feedrate programming in ipm or mmpm |
G95 | Feedrate programming in ipr or mmpr |
G96 | Constant surface speed (feet per minute or metres per minute) |
G97 | Spindle speed programming in rpm |
G98 | Axis presetting with mirror |
G99 | Delete G92 |
