Osai 10 Series command SSL is used with G96 to set the maximum rpm that the spindle is allowed to run during CSS.
Contents
SSL=value
Parameter | Description |
value | Is a value that can be programmed directly with a decimal number or indirectly with an E parameter. |
Examples
SSL = 2000 ;Assign a spindle speed limit of 2000 rpm E32 = 1500 SSL = E32 ;Assign a spindle speed limit of 1500 rpm
Important
Make sure you enter this value in the part program prior to entering G96 blocks.
