Right Tap Selection Tips by Sandvik Coromant – Video for CNC Machinists
Right Tap Selection
The success of any tapping operation depends on the use of the appropriate tap along with the correct set-up.
This video focuses on a number of factors to be considered in selecting the right tap for a specific job.
Right Tap Selection Recommendations
While choosing the right tap for a component you should consider
  • Component material.
  • Type of Hole (Blind hole or Through hole).
  • Component batch size (large quantity of same material components or small quantities of multiple different material components.).
