Manufacturing plays a big role in society, and CNC now has reached at such a level that thinking manufacturing without cnc technology is impossible.
Role of Manufacturing in Society a Video
More ...
Manufacturing: Not just a Man’s job – Now Women are on Shop Floor
April Senase, 35, is a trailblazer. She has worked numerous factory jobs for 13 years — often as the first, or only, woman on the production floor. She makes nearly…
Mori Seiki NTX1000SZM 11Axis – MacKay Manufacturing Inc.
A very nice and brief video showing (Mori Seiki NTX1000SZM) most of the cnc machining operations like Turning Drilling Tapping Glenn Coker, Programmer and Machinist for MacKay Manufacturing, Inc. in…
Fanuc G76 Fine Boring Cycle Video Demonstration – CNC Mill
Video showing a Horizontal boring mill running G76 boring cycle ContentsFanuc G76 Fine Boring CycleFanuc G76 Fine Boring Cycle Operation Fanuc G76 Fine Boring Cycle Fanuc G76 Fine Boring Cycle…
Seco Tools – PCD Drills for Composite Materials [video]
PCD Drills – THE NEXT STEP FOR COMPSITE MATERIALS With the PCD drill ranges CX1 and CX2 Seco tools is taking the next step in the development of tools for…
Okuma G74 Reverse Tapping Cycle
ContentsOkuma G74 Reverse Tapping CycleProgrammingParametersMachining SequenceDetails Okuma G74 Reverse Tapping Cycle G74 Reverse Tapping Cycle Programming G74 X__Y__Z__R__P__Q__F__ Parameters Parameter Description X,Y Coordinate values of hole position Z Hole bottom…
Video for CNC Machinist
Here is a video for the cnc machinists. Video of cnc lathe machine with driven tools.
Right Tap Selection Tips by Sandvik Coromant – Video for CNC Machinists
ContentsRight Tap SelectionRight Tap Selection Recommendations Right Tap Selection The success of any tapping operation depends on the use of the appropriate tap along with the correct set-up. This video…
Thread Infeed Tips from Sandvik Coromant a Video
This video from Sandvik Coromant briefly describes thread infeed methods like Modified Flank Infeed Incremental infeed Radial Infeed The video also briefly describes where and when to use which thread…
Introduction to SINUMERIK 808D – Video Tutorial Turning Part 1
ContentsSINUMERIK 808D IntorductionFree Download SINUMERIK 808D on PCSiemens Sinumerik 808D Manuals SINUMERIK 808D Intorduction This video introduces Sinumerik 808D and shows the drawing of the workpiece which will be completed…
CNC Lathe Soft Jaws Cutting for ID Gripping – Video by Haas
A very brief and informative video by Haas Automation for CNC machinists which explains how to properly cut cnc lathe soft jaws for ID gripping. Note: It is highly recommended…
Switch on & Reference Axis SINUMERIK 808D – Video Tutorial Turning Part 2
How to Switch-On and Reference Axis This video tutorial shows how CNC turning machine with Sinumerik 808D CNC control is Switched-On. As every cnc machine needs a way to reference…
Control Panel Introduction SINUMERIK 808D – Video Tutorial Turning Part 3
This video from Siemens briefly describes the keys and screen areas of Sinumerik 808D control panel. After watching this video a CNC machinist can easily distinguish different areas of CNC…
Drawing & fixing the workpiece SINUMERIK 808D – Video Tutorial Turning Part 4
SINUMERIK 808D Tutorial Turning Part 4 video describes the drawing, cutting strategy and how to fix the workpiece. Also gives some tips as How to choose raw material dimension when…
CNC Lathe Soft Jaws Proper Boring/Cutting Method – Video by Haas
ContentsCNC Lathe Soft Jaws Video Series by Haas AutomationThis Video Answers Following Questions CNC Lathe Soft Jaws Video Series by Haas Automation A very brief video which described the proper…
Tool Setup on Machine – Sinumerik 808D Video Tutorial Turning Part 5
This video describes how tools are chosen for different machining operations and Tool setup on CNC lathe machine with Siemens Sinumerik 808D cnc control. Normally there are many tools available…
Coordination System Introduction on Sinumerik 808D – Video Tutorial Turning Part 6
As you have seen in previous videos of Sinumerik 808D Turning Video Tutorial Series that cnc lathe machine has been fully set up for component (cnc lathe jaws has been adjusted…
Tool Offset Setting Sinumerik 808D – Video Tutorial Turning Part 7
This video very briefly describes every detail of tool offset setting or tool setup on CNC Lathe with Siemens Sinumerik 808D cnc control. As actual selection of tools and how…
Osai High Level Geometric Programming (GTL) Example
Osai 10 Series program example using Osai GTL (High Level Geometric Programming Language). Osai High Level Geometric Programming (GTL) Example Profile repetitions executed with 2 passes N1 (DIS,”GTL EXAMPLE WITH…
