A very simple cnc program example which shows the use of Siemens Sinumerik CYCLE83 Deep Hole Peck Drilling Cycle.
Contents
Siemens Sinumerik CYCLE83 Deep Hole Peck Drilling Cycle Overview
CYCLE83(RTP, RFP, SDIS, DP, DPR, FDEP, FDPR, DAM, DTB, DTS, FRF, VARI)
RTP Retraction plane (absolute)
RFP Reference plane (absolute)
SDIS Safety clearance (enter without sign)
DP Final drilling depth (absolute)
DPR Final drilling depth relative to the reference plane (enter without sign)
FDEP First drilling depth (absolute)
FDPR First drilling depth relative to the reference plane (enter without sign)
DAM Amount of degression (enter without sign)
DTB Dwell time at final drilling depth (chip breaking)
DTS Dwell time at starting point and for swarf removal
FRF Feedrate factor for the first drilling depth (enter without sign) Range of values: 0.001 … 1
VARI Machining type (Chip breaking=0, Swarf removal=1)
All the working and parameters of Siemens Sinumerik CYCLE83 Deep Hole Peck Drilling Cycle has already been explained here Siemens Sinumerik CYCLE83 Deep-Hole Peck Drilling Cycle.
To understand difference between DP and DPR read Sinumerik 840D CYCLE81 Drilling Centering Cycle Programming
Siemens Sinumerik CYCLE83 Deep Hole Peck Drilling Cycle Example Code
Sample Program Siemens Sinumerik CYCLE83 Deep-Hole Peck Drilling
N10 G0 G17 G90 F50 S500 M4 N20 D1 T12 N30 Z155 N40 X80 Y120 N50 CYCLE83(155, 150, 1, 5, 0 , 100, , 20, 0, 0, 1, 0) N60 X80 Y60 N70 CYCLE83(155, 150, 1, , 145, , 50, 20, 1, 1, 0.5, 1) N80 M02
Call of cycle; depth parameters with absolute values.
Cycle call with relative data for final drilling depth and first drilling depth, the safety clearance is 1 mm and the feedrate factor is 0.5
