The Drilling Calculator App from Sandvik Coromant is designed to support engineers, programmers and machinists when working with drilling and tapping tools.
This app will help machinists calculate optimal cut settings based on job parameters. It also includes hole size calculations for tapping and ISO tolerances for bore and shaft.
With the input of production values, it is also possible to calculate various costs related to a drilling operation, such as the tool cost per component, the insert cost per component and the total machining cost per component.
Both machining and cost calculations include an option for single input or a compare mode.
The app works with both metric and inch measurements.
