The Seco MDT (Multi Directional Turning) system uses single toolholder and insert for turning, profiling, and grooving in both axial and radial directions. For complex components with many grooves and profiles, one tool replaces several conventional tools.
The system can be used for
• Turning
• Profiling
• Grooving
• Parting-off
Seco MDT has a unique insert clamping method – Secoloc; a combination of top clamp and serrated contact surfaces between the insert and toolholder offers superb stability.
Seco MDT is versatile enough to improve productivity by reducing tool changes and machine stops. The Seco MDT system also simplifies tool handling and stocking requirements by replacing the need for several conventional tools.
