Seco Mobile Calculator / Seco Tools Assistant Mobile App is useful for cnc programmer, cnc machine setter, cnc machinist. This is a very simple mobile application.
This mobile application is from Seco Tools.
Seco Tools Assistant Mobile App for CNC Machinist
Seco tools assistant is a mobile application which makes our daily calculations in the cnc machine workshop much easier. You can easily make both inch and metric calculations. The following calculation can be easily calculated with this Seco Mobile Calculator, Milling:
- RPM
- Cutting speed
- Feed speed
- Metal removal rate
- Average chip thickness
Turning:
- RPM
- Cutting speed
Drilling:
- RPM
- Cutting speed
- Table feed
- Drilling – Metal removal rate
- Boring – Cross section area
