Selca G17 G18 G19 Plane selection
Contents
G17 Plane selection XY
G17 Plane selection (XY is the machining plane, Z is the perpendicular axis)
G17
Enabled: (default) until aG16, aG18, or aG19 is programmed.
G17 Selection of planes different than XY
G17 Axis1 Axis2 Axis3
Parameter | Description |
Axis1 | defines the abscissa axis. |
Axis2 | defines the ordinate axis. |
Axis3 | defines the perpendicular axis. |
Enabled: until a G17(without parameters), a G18 , or a G19 is programmed.
G18 Plane selection ZX
G18 Plane selection (ZX is the machining plane, Y is the perpendicular axis)
G18
Enabled: until aG17 or aG19 is programmed.
G19 Plane selection YZ
G19 Plane selection (YZ is the machining plane, X is the perpendicular axis)
G19
Enabled: until a G17 or a G18 is programmed.
