Selca G27 First point of a SPLINE curve linking a series of at least 5 points
Contents
G27 X... Y... [I...] [Q...] [D1=1]
Parameter | Description |
X, Y | Coordinates of the first point of the curve. |
I | Segmentation tolerance (default value I=0.05 mm). |
Q | Angle on the starting point. |
D1=1 | Closed curve. |
Enabled: until a G29 is programmed. The points of the curve (X… Y…,X… Y…, etc.) shall be programmed between a G27 and a G29.
