Selca G43 G44 Paraxial radius compensation
G43
G43 Paraxial radius compensation: the compensation is added to the coordinate
G43 [X...] [Y...]
Enabled: only in the block in which it is programmed.
Note: to be used only in case of paraxial milling operations (it is better to use G41/G42).
G44
G44 Paraxial radius compensation: the compensation is subtracted from the coordinate
G44 [X...] [Y...]
