Selca G4724 G4725 Planetary milling
G4724 Cancels G4725
G4724 Cancels G4725 (only for S4000 Series CNCs)
G4724
G4725 Planetary milling (only for S4000 Series CNCs)
G4725
ParameterDescription
Iradius of the circle in mm of the circular mill path (if not programmed I=1).
Jprofile increase in mm between circles (if not programmed J=1).
Qmachining allowance (if not programmed Q=0).
Kmachining mode selection:
K=1 flush machining.
K=2 not flush machining.
This parameters defines the direction of machining i.e. according to the profile path or not.
Parameter K1 indicates that machining is agreeing and the movement between circles is flush.
Parameter K2 indicates that machining is disagreeing and the movement between circles is opposite to the flush.
