Selca G67 G68 G69 Static TCPM
Contents
G67 Cancels G68/G69
G67 Cancels G68/G69 static TCPM
G67
G68 Static TCPM for rotary tables
G68 [A...] [B...] [C...] [X...] [Y..] [Z...] [D1=...]
Parameter | Description |
A B C | table rotation values. The system calculates the new position of the tool with respect to part zero after the rotation of the table. |
X,Y,Z | displacement values of the point of rotation with respect to table center. |
D1= | Table number (from 1 to 4. If not programmed D1=1). |
Enabled: until a G67 is programmed.
G69 Static TCPM for rotary heads
G69 [A...] [B...] [I...] [J...] [Q...] [D1=...]
A B | head rotation values. The system calculates the new position of the tool with respect to part zero after the rotation of the head. |
I, J Q | positive or negative values to be added to the distance between head center and tool virtual point. I, J, Q, operate on the configured axes: spindle, abscissa and ordinate respectively. |
D1= | head number (from 1 to 8). (By default D1=1). |
