Selca G736 Surfaces defined by a plane profile and one or more section profiles: plane profile and parameters
G736 I... [X... Y...] [J...] [K...] [Q...] [D0=...] [D1=...] [D2=...] [D3=...] [D4=...] [D5=...] [D8=1]
ParameterDescription
Idistance between passes on the section profile containing the K1 parameter (see G737).
X,Ytool approach point to the plane profile.
Jfinish stock allowance.
Kmachining mode for the linking radii of the plane profile, depending on the section profile:
K1 variable radii (default value).
K2 constant radii.
Qselects the type of passes for open plane profiles:
Q1 unidirectional passes (default value).
Q2 bi-directional passes.
D0selects type of milling:
D0=0 plane milling (default).
D0=1 special use of G736 for pocketing concaves surface.
D0=2 spiral milling.
D1=Z-rapid move out coordinate for unidirectional passes.
D2=tool clearance value for unidirectional pass end/start. (D2=2 by default).
D3=spiral milling cord error (default D3=0.01 when using D0=2).
D4=minimum spiral milling cord (dafault D4=0.1 when using D0=2).
D5=maximum spiral milling cord (defaultD5=2when using D0=2).
D8=1programsisland milling cycle,oncondition thatD0=1is programmed.
