Selca G737 Surfaces defined by a plane profile and one or more section profiles: section profiles
Contents
G737 [Q...] [K1]
Parameter | Description |
Q | number of the section profile (fromQ1to Q10).Q=1by default. |
K1 | if the section profile contains the K1 parameter, passes are calculated according to the I distance programmed in G736. If K1 is not programmed, passes will be calculated on the first section profile. |
