Selca G760 G761 Axis travel delimitation
G760 Cancels G761
G760 Cancels G761
G760
G761 [X...] [Y...] [Z...] [I...] [J...] [K...] [Q...] [F...] [D0=...] [D1=...] [D2=...] [D3=...] [D4=...] [D5=...]
ParameterDescription
X,Y,Zlower axis travel limits.
I,J,Kupper axis travel limits for X,Y and Z axis respectively.
Qselects NC behaviour in case of axis overtravel with respect to the programmed limits:
Q0 an error signal (ERR 98) is displayed.
Q1 all the points outside the limits are projected on the limits.
Q2 all the points outside the limits are eliminated.
Ffeed rate to be used outside the limits (only with Q1). The default value is the programmed feed rate.
D0=specifies the profile section part to be executed at the programmed feed rate (with Q1 only). D0 will be subtracted from the upper limits I, J, K and added to the lower limits X, Y, K. If D0 is not programmed, the entire profile will be executed at the programmed feed rate.
D1=percentage of feed rate variation (only with Q1)(D1=1 by default).
D2=tool clearance value from pocket walls outside the limits(only with Q1)(by default D2=1).
D3=incremental or absolute withdrawal height (only with Q2) (D3=0 by default).
D4discriminator for D3:
D4=0 D3=incremental height (D4=0 by default).
D4=1 D3=absolute height.
D5discriminator for plane movements to detachment position:
D5=0 programmed (default).
D5=1 rapid.
Enabled: until a G760 is programmed.
