Selca G779 Profiled pocket milling cycle with finishing pass
Contents
G779 [X... Y...] [J...]
Parameter | Description |
X,Y | coordinates of mill positioning point before starting a cutting path. If this point is not programmed, the tool will move to the starting point of the first pass. |
J | distance between passes, in mill radius units (J=1.6 by default). |
