Selca G787 Grid pattern machining repeat supercycle
G787 X... Y... [D1=...] [D2=...] [D3=...] [D4=...] [D5=...] [D6=...] [D7=...]
ParameterDescription
X,Ystarting point coordinates.
D1=number of figures per line.
D2=distance between figures on the line.
D3=angle formed by grid lines and X-axis (D3=0° by default).
D4=number of figures per column.
D5=distance between figures on the columns.
D6=angle formed by grid lines and X-axis (D6=90° by default).
D7=angle of rotation of the single machining (D7=0° by default). Machining cycle to be repeated must be programmed after a G787. A G780 enables the cycle. The identifier of the machining to be executed is stored by the system under the P99 parameter.
