Contents
G79 Last point of polygonal pocket
Selca G79 Last point of a polygonal pocket with finish pass
G79 X... Y...
G79 Circular pocket milling
G79 Circular pocket milling (roughing & finish cycle)
G79 X... Y... K... [Q...] [I...] [J...] [D0=...][D1=...] [D2=...] [D3=...] [D4=...] [D5=...] [D6=...] [D7=...] [D9=...]
Parameter | Description |
X,Y | pocket center coordinates. |
K | pocket diameter (negative = clockwise cutting). |
Q | internal diameter. |
I | stock allowance (default value I=0). |
J | distance between passes in tool radius units (default value J=1.6). |
D0 | machining mode selection: D0=0 concentric cuts and Z – increment only (default). D0=1 spiral path cuts and Z – increment only. D0=2 spiral path cuts and X, Y, Z – increment. |
D1= | pocket starting depth. |
D2= | pass depth. |
D3= | pocket bottom depth. |
D4= | clearance distance (default value D4=2 mm). |
D5= | radius value for tool automatic approach and exit during the finish pass (default value D5=I).. |
D6= | wall taper rate (default value D6=0- vertical wall). |
D7= | percentage of feed rate variation during depth increment (default value D7=1). |
D9= | clearance value from pocket walls during tool repositioning at end of cycle (D9=0.5mm by default). |
