Selca G797 Circumference pattern machining repeat
G797 X... Y... D1=... D2=... [D3=...] [D4=...] [D5=...]
ParameterDescription
X,Ycircumference center coordinates.
D1=number of figures.
D2=circumference radius with sign. If the radius is negative, figures will be machined CW; if the radius is positive they will be machined CCW.
D3=angle formed by the first figure and the X-axis (D3=0 by default).
D5=discriminator for figure rotation:
D5=0 no rotation (default value).
D5=1 the machining will be rotated.
The machining cycle to be repeated must be programmed between a G797 and a G780 cycle enable function. The identifier of the machining to be performed is stored by the NC into the P99 parameter.
