Selca G82 Deep mixed drilling cycle
G82 [X... Y...] Z... I... J... [Q...] [K...] [F...] [D0=...] [D7=1] [D8=...] [D9=1] [D10=...] [D11=...] [D12=...] [D13=...] [D14=...]
ParameterDescription
X,Yhole coordinates.
Zhole bottom plane.
Idepth increment prior to dwell for chip breakage.
Jhole starting plane.
QZ axis clearance plane.
Kdwell time for chip breakage (in tenths of a second, in alternative to D10).
Ffeed rate.
D0=when descending after a chip discharge, tool rapid move changes to the programmed feed rate at a distance of D0 mm from previous depth.
D7=1tool retracts to the Q plane for chip discharge.
D8=scaling factor for rapid positioning feed (value include between 0 and 1;D8=1 by default). (Only for S4000 CNCs).
D9=1never mind where the machine is, the cycle is execute in XY position, without to programming XY. (D9=0 by default).
D10=rapid detachment value after each performed increase (default D10=0; in alternative to K).
D11=increasing value of the lead-in at feed F*D13 (default D11=0).
D12=increasing value of the section to cover at constant increase I and detachment D10 from the reached position. Once reached D12, in the last section, till the position Z is reached, the increment is executed in depth with a scaling factor (D14), before a rapid return for chip discharge at J or Q.
D13=multiplying factor of F for the section defined by D11 (default D13=0.7).
D14=scaling percentage of the increases for the section between D12 and Z (default D14=10).
Enabled: until a new fixed cycle or a G80 is programmed.
