Selca G86 Boring fixed cycle
Contents
G86 [X... Y...] Z... J... [Q...] [K...] [I...] [F...] [D0=...] [D7=...] [D8=...] [D9=1]
Parameter | Description |
X,Y | hole coordinates. |
Z | hole bottom plane. |
J | hole starting plane. |
Q | clearance plane for tool retraction in rapid with spindle OFF. |
K | dwell time at the bottom of the hole with spindle ON(in tenths of a second). |
I | dwell time at the bottom of the hole with spindle OFF (in tenths of a second). |
F | feed rate |
D0= | angle of the bore cutting edge after spindle orientation performed by the PLC in the same direction as the rotation direction. |
D7= | tool off the wall value along D0 angle (D7=0.5 by default). |
D8= | scaling factor for rapid positioning feed (value include between 0 and 1;D8=1 by default). (Only for S4000 CNCs). |
D9=1 | never mind where the machine is, the cycle is execute in XY position, without to programming XY (D9=0 by default). |
Enabled: until a new fixed cycle or a G80 is programmed.
