Selca G872 ON /OFF touch probe measuring cycle in space
G872 [X...] [Y...] [Z...] [I...] [F...] [R]
ParameterDescription
X,Y,Zexpected coordinates of the point to be measured.
Iclearance.
Fmeasuring cycle feed rate.
Rrapid move up to I… mm from the expected point. If I is not programmed, the entire move will be executed at the programmed feed rate.
Enabled: only in the block inwhich it is programmed.
